Question about Office Depot Ativa D5772 Phone
Lost manuel for Ativa AVR-4.
New machine and tired to plug directly into phone jack and won't work. When pluging directly into our 2 line phone we loose line 2 but answering machine works. Is this right?
You may acquire a copy of the manual in pdf form.
Click Here!
Or Here!
It is the fully authorized Ativa AVR-4 answering Machine handbook from Ativa on 03/22/09
Posted on Mar 28, 2009
I need a user's manual for an Ativa 5.8 digital phone. Model #AD583. SN EH100053340
office depot gots alls da manuels u ned. google u r phone an u will fnd da nmanuel PDF to download free!! l.o.l
Jun 15, 2012 | Lands Phones
Hooking up the HP 640 Fax
there are 2 phone jacks on the back.. one is marked with an ( L ) or is spelled out (Line) ...the phone line from the wall should be plugged into that jack marked L or Line
Jun 04, 2010 | HP 640 Inkjet Fax Machine
Keeps clicking between speakers on and hp input on...no sound
had same problem with my denon 1910 .... clicking with no sound and some modes indicating not available. Blowing the dust out of the headphone jack solved the problem !!!!!!!!!!!!! ... the denon people could not even figure it out. Thanks sooooo much.
Dec 30, 2009 | Denon AVR-589 Receiver
How to set time and date on Ativa? AVR-4 Digital Answering System?
how do i program my phone to show name and phone when someone is calling and how do i change time nad date and year i have a ativa digital answering machine
Aug 21, 2009 | Lands Phones
I'm unable to receive or send faxes
Are you sure the line is good? You can try a plugging a telephone into the line to check it.
If you press the "hook button" (or whatever it is called on that machine) do you hear a dial tone?
is the phone cord plugged in snugly and in the proper jack on the machine? Is the cord good?
These are a few things to try.
If all of that checks out, then the phone board on the machine is shot.
May 26, 2009 | Panasonic PANAFAX UF-6000 Fax
Second line not working
The phone will show that "line in use" message when it's not connected correctly.
If your two phone lines come in to one jack, make sure you are using a 4-wire line cord connected to the "line 1 and line 2" jack on the phone. You may be using a 2-wire cord so the second line isn't reaching the phone.
If the two lines are on separate jacks you need to connect line 2 to the separate "line 2" jack.
If you know for a fact that both lines are properly connected to the phone and it still doesn't see the second line, then it's time for a new phone.
Dec 10, 2008 | AT&T E2562 Cordless Phone
Error message 232
Hello Lazylizard, basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Oct 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Phone connection for Lucent 854
You can get a splitter for it which will then divide that one phone jack into 3 out or 4 out which ever you need. the only problem that you might run into is how close the phones might be to each other. Otherwise there isn't much other ways around it with only one phone jack.
Mar 31, 2008 | Lands Phones
DTIM with digial phone service
I install these types of alarms.
First, What is usuallly plugged into the cables main box? Usually it is a jack. This would run to the main phone lines in the house, and allow you to have service at alll the jacks in the house. If this was not the case, then you usually just plug your phone in directly. Either way, the tel #1/2 on the main box is the same principal as the two main lines comming in off the street with the phone company. If there is a jack, get another and a peice of 2/4 strand wire. (If you have a 8 pin bell jack let me know if not follow.) connect the red and green at the main jack to the red and green of the new jack. Plug in the DTIM and go. If it is just a plug in the phone directly then i suggest getting three jacks. plug a regular phone cable from tel 1/2 into the first jack. Then connect the red and green to the next red and green. this is the DTIM jack. Then do the same to connect a phone jack for your phone. I have installed lots of simon 3 systems but never with a DTIM> I also install alot of GE Allegro panels and they come with the DTIMs. Are you having it learn in properly? It should be group 39 on the system. At least it is on the other panels.
Good luck.
Sep 08, 2007 | GE Security Simon 3 Wireless Home Security...
Office Depot Ativa D5772 Phone Logo
965 people viewed this question
Top Office Depot Lands Phones Experts
ashburton
Zelio Picanso
Tom Chichester
Are you an Office Depot Lands Phone Expert? Answer questions, earn points and help others
