Question about Ricoh Aficio 250 Copier
I need a lazer unit according to a repairman
Are the lazer units for this model still available and aprox. cost available.
  • ken_jones Jan 12, 2009
    Dave coyle - after the technicians came the copier is not turning on, so I can not get the codes off of it.
  • 3 Answers
Are u sure u do not just need a polygon mirror motor. what are the visible srevice code numbers in the display.
Posted on Jan 09, 2009
  • davecoyle Jan 12, 2009
    sounds more like a power supply problem than a laser problem. possibly a blown fuse on the p.s. also did the machine power up before the techs go there. did they cause this no power condition
Have Sanyo model DP19648. Screen is black, sound works. Powers on and off, green(power)light works with tv power button on set and both remotes. Set stays on with sound until powered off.
I would try a new Tcon board, they aren't all that expensive, only other thing to do is check the LVDS and flat cables to be sure they are plugged in ok between the main and panel to and from the Tcon
Nov 08, 2017 | Sanyo Televison & Video
I dropped my unit and the screen cracked. can it be fixed? how much will it cost?
If by "unit" you mean laptop then yes it can be fixed aprox.75-150 bucks for the screen and around 75 to install it.
May 09, 2011 | Computers & Internet
Sc322-00
you are not mention the product number or model any have SC-322 is related to lazer diode unit (Lazer synchronization error) may be poor connection between LD unit and BICU bord or LD unit defective or BICU defective most of this cases we are facing LD unit defective. If you are not a technical person please call right person to solve this problem
Thanks
Dec 17, 2010 | Gestetner Office Equipment & Supplies
LE MESSAGE 329
329 LD unit beam pitch adjusted incorrectly
The LD unit HP sensor does not detect
the ON condition while changing the LD
unit position for correcting the LD
position or changing the dpi.
• After initialization of the SP modes,
SP2-109-3 or SP2-109-4 was not
executed.
• The harness is blocking the LD drive
(PCB), preventing adjustment of the
pitch.
Lazer issue.Execute above sp modes or u need to take the lazer unit out and see if anything in the way.
Nov 21, 2010 | Ricoh Aficio 1035 Copier
I have a xbox360 game and does not read as a game it read as dvd
This can be caused by a dirty laser in the drive. Try cleaning the laser with a Q-tip and alcohol. If this does not fix the problem then the laser may need to be replaced. Contact Microsoft to see if the unit is still under warranty.
If the unit is not under warranty, visit www.wiredextreme.com or call toll free 1-888-389-3038. We are a console repair company based in Texas, and can get your console up and running in no time. All of our repairs come with a standard 90 day warranty that covers the entire console, not only our repairs. Extended warranties are also available at additional cost
Jun 21, 2010 | Microsoft Xbox 360 Console
Not recognising that there is a cd in there. keeps saying 'no disk'
Hi there , have you tryed cleaning the lazer lens very gentle with a cotton bud , the lazer could be quite costly to replace , there is a very small ajustment on the lazer inside the unit but would need someone with a bit no how to ajust the setting a very small amount to see if the lazer will work better .
May 10, 2009 | Audio Players & Recorders
Disc spins- won't load
i suggest anyone who cant get a movie to play ,should get rid of the piece of **** & save $ &headaches .go buy a up to date model,you get what you bargain 4.(**** happens!)
Apr 07, 2009 | Mintek MDP-1020 Portable DVD Player
TOC ERR
this is caused from the pickup needing to be cleaned(lazer) remove deck remove small phillips screw on top plate use a damp q-tip (alcohal) gently rub the lazer top with the q-tip allow to dry aprox 10min reasemble and enjoy. Also make sure u don't need a security code for your radio before u unhook the power plug!!!!
May 16, 2008 | Kenwood KDC-MP228 CD Player
Ricoh Aficio 250 Copier Logo
51 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
