Question about Thetford Norcold RV Cooler/Freezer
The refrigerator 1985 southwind stopped working
It stopped working so we were wondering is there a fuse somewhere we need to check, the gages for the water level, septic and propane also stopped working. please help there is no power getting to this area.
Curb weight 1986 29 foot southwind motorhome
The weight is about 17000 lbs.
The weight is posted somewhere in the RV. Could be on a visor, inside a closet or cabinet door, or on a door panel.
Oct 09, 2016 | RVs
Cigarette demister and horn all stopped working at the same time
try to check each individually and see if they work.. there is aperently a botched ground somewhere..
Dec 08, 2013 | 1985 Peugeot 309
Battery wont charge. voltage meter and temperature gage dont work. speedometer sensor out.
check fuse, if fuse is ok. check rectifier and alternator connections. usually the connections get dirty.
Feb 03, 2013 | 1985 Honda GL 1200 Aspencade Gold Wing
Speedometer stopped working, can/t find where it connects to the transmission due to skid plate. not sure if it needs to be removed before replacement of cable. Also tachometer and fuel gauge are not...
Definitely sounds like a fuse issue. look at the owners manual under fuses. find the location of the one marked "fuel gauge" and check. Usually there are more then one circuit included for the fuse, which may be the other circuits that are not working. If there was recent work done, there may be a loose connection on a terminal going to the distributor.
Jan 07, 2018 | 1985 Toyota Land Cruiser
Engine runs rough and istrument Gages not working
It sounds like you need to inspect the wiring harness and look for broken wires and any wires that are hanging they may not be connected, the black exhaust is caused by a choke plate that is not opening on the carb the electric choke is not getting any voltage through the wire or the choke plate is out of adjustment it should be wide open after 5 minutes of running, check the fuses to be sure there is no blown fuses and check the wire that goes to the carb. to ensure it has 12 volts.
Dec 02, 2009 | 1985 Ford F150
My digital speedometer and other gages will not work 1985 thunderbird
sounds like an ignition fuse has blown, check them . hope this helps
Apr 14, 2009 | 1985 Ford Thunderbird
Instrment cluster guages not working
Suspect a fuse ,check them they are under the bonnet in a clear box you will see a burnt one easy.Some times it helps to wiggel them one by one .
Jan 05, 2009 | 1985 Mercedes-Benz 190
My gages dont work what do i look at first to fix the problum
If multiple gauges dont work always start with checking fuses
Nov 29, 2008 | 1985 Honda Civic
Thetford Norcold RV Cooler/Freezer Logo
97 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
