Question about Keurig B50 Coffee Maker
Machine Stopped Working
Nothing happens when buttons are pressed. LED display shows Auto Off and Brew but screen never changes when buttons are depressed. Water container is full and coffee in place???
  • 1 more comment
  • ivanputs Jan 10, 2009
    Funny, mine just started doing that this morning. Hopefully someone has an idea of how to fix it.
  • tduffy Jan 18, 2009
    The brew light won't go on the B50 will not work,
  • cmayfield Jan 27, 2009
    i have the same problem, water heats up, gets ready, i push the button and nothing happens.
    Problem Solver:
  • 25 Answers
A couple of things: the buttons themselves are bad or its the circuit board.
Posted on May 14, 2009
TV TURNS ON BUT NO DISPLAY AT ALL.
do a reset by manually holding down the power button, sometimes that works
Jan 28, 2014 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Tip
How to program Cuisinart to grind or brew?
The procedure is as follows:--For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position. This will help.Good luck.
on Mar 08, 2010 | Coffee Makers & Espresso Machines
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
Sep 13, 2012 | Breville You Brew - Single and Carafe...
Hi - our GAGGIA TITANIUM is displaying
Dear, friends first of all please check your machine display. Is it displays full character or something missing character. If it shows "SEL" it can be select product ready for use or you have go in service menu.
First of all switch off machine and clear your waste drawer and fix it .remove Brew unit clean and fix it.
Then..hold down the 3rd button( Lungo) and Hot water, switch ON machine. On display it shows machine software version and the it show some digit.
By pressing simultaneously you can check the brewing motor,grinder motor, Al l senser switch working or not...
Please do.
Thanks N regards,
Shrikant Shinde
Mumbai( India) .
Sep 08, 2017 | Coffee Makers & Espresso Machines
I need NOMA N1508 manual.
answer 1 Function and operation
1 - This timer has 3 working modes
a - Auto Mode(AU)
b - Auto and Temperature Control Mode (AC)
c - Manual Mode (LL)
Press "MODE" button and the LED display will cycle through these three modes.
2 - There is an output indicator light which turns Green (On all modes) and red (Off - manual mode)
3 - There is a bettery backup that can retain programs for about 1 week after power outage.
Operation
1 - On first use . Connect the unit to 125V AC power source. The LED display blinks 'C'. The unit at this moment is in initial state, where time and program need to be set.
2 - Press the "TIME" button, the LED display will now show "12.00", now the unit is entering time setting mode
a - The time interval for this product is 15 minutes
b - Press "TIME" button again. LED dislays 12:15 with each press of the time button the time increases by 15 minutes. If you press and hold the time button for 2 seconds the LED will increase rapidly.
c - After setting the time, press the enter button and the LED will display current time setting.
d - To change the clock press the "Enter" and the "TIME" buttons simultanously to enter the editing mode. Press the "TIME" button to adjust the time. Press the enter button to confirm
3 - To program press "mode" button once and the LED will display "AU" which stands for Auto Mode, press the "MODE" button once again and the LED will display "AC" which is the Auto and Temperature Control Mode. Press the "MODE" button once more and the LED will display "LL" which is Manual Mode. Press enter to confirm the selected mode. Press "MODE" button to role over these three options.
a - Auto Mode
Press "MODE" button and the unit will enter Auto Mode, LED displays "AU"
- Press "ENTER" button to confirm. LED displays "P". Press "TIME" button to set program ON time.
- After the program ON time is set press "ENTER" button to enter program ending time. LED will display "E". Press the "TIME" button to set the ending time.
- Press "ENTER" button to return to normal time display mode.
- The program indicator will be turned on after the ON time and ending time have been programmed
- Press the "TIME" button to review the program ON time setting and program ending time setting. The LED displays "P" and "E" respectively. After that the LED displays the current time.
- In case you want to modify the setting repeat step "a".
*** Note: When entering your program if no action takes place within 15 seconds it will go back to the time screen.
Press the "MODE" button and the LED will display "AU". Press the "MODE" button again and the LED will display "AC". press the "ENTER" button to confirm.
- The timer activates the load only when the folloewing two conditions are met:
1 The temperature is below -10
2 The program on time p is reached
For instructionsn on how to set the program ON time and the program ending time please refer to the Auto Mode fucntion
- The program indicator will be turned on after the ON time and the ending time have been programmed.
- When the program ending time is not yet reached, the load will be deactivated if the temperature rises above -7 and will be activated again if the temperature drops below -10. Once the prgram ending time is reached the load will be deactivated regardless of the temperature.
C - Manual Mode
Press the "MODE" button to select Manual Mode. When the LED displays "LL" press the "ENTER" to confim. The LED returns to show the current time. Press the "TIME" button to activate the timer the LEd will display ON. Press the "TIME" button again the LED will display off.
- In Manual Mode the output indicator will display red when the load is deactivated and green when activated.
- To exit manual mode press "TIME" and "MODE" buttons simultanously and the unit will return to Auto mode. The loading will be activated and deavtivated according to the previous setting.
4 Output indicator
1 - In Auto Mode ort Auto Temperature Control Mode when the loadind is deactivated the output indicator tunrs off.
2 - In Manual mode the outpur indicator turns red when loading is deactivated.
3 - In Manual Mode, Auto Mode and Auto Temperature Control Mode the output indicator turns green when the output is activated.
To reset all of your settigns including current time and programs, press and hold the "ENTER" button for 5 seconds from the "TIME" mode. answered 3 weeks, 2 days ago by Anonymous
Jan 11, 2011 | Sport & Outdoor - Others
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
Aug 10, 2009 | Keurig B60 Coffee Maker
How to program to automatic brew
But, like the person said, we would need your exact model # to be more specific.
-Tha Mp3 Doctor
Dec 29, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
After static shock, keypad on fax machine is not working...everything else ok
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Nov 30, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Keurig B50 Coffee Maker Logo
371 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
