Question about Toshiba Satellite M30-832 Laptop Charger (1300724LMD0000029)
My laptop charger is not working - Toshiba Satellite M30-832 Laptop Charger (1300724LMD0000029)
    Novelist:
    Champion:
  • 233 Answers
Two possible causes:
1)your laptop charger is dead or malfunction
2)your laptop dc jack is loose or malfunction
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
http://www.chargerbuy.com/replacement-toshiba-satellite-m30-ac-adapter-15v-5a.html
Posted on Nov 22, 2012
SOURCE:
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Laptop charger gets disconnected
Is the Acer E1-571 charger broken? if so, you need a new replacement charger to support the Acer laptop works.
In order to confirm the where is the question, please kindly try it with another similar charger to confirm if the laptop still works.
Aug 12, 2013 | Acer Aspire E1-571-6650 Laptop
Laptop won't charge. Replaced battery and charger and still does not work.
Please check the connector / port where u plug-in the charger. Does it happen with all other compatible chargers or only with the one you have. Also try charging some other compatible laptop with the same charger. If that works, it means there is some problem with the port. Its not making the connections well.
Aug 12, 2012 | Toshiba Satellite L655-S5103 Laptop
My compaq cq40 laptop charger is not working
Before you make a decision about the next step, maybe you would like to know why the laptop charger is not working. Here are some commonly found reasons for this problem.
  • You have been using the wrong laptop charger for your machine, or someone else has been using your laptop charger for another machine. This may seem like a harmless act, but it affects the battery on your laptop, and charger you are using as well.
  • Your laptop battery has become weak and worn out from excessive use. Due to this the battery is not charging at all (or charging very slowly) when you plug in the charger. In this case there is absolutely nothing wrong with the charger itself.
  • The wire of the laptop charger has got a distinct curve at one point, and this is restricting it from transmitting power. You need to look out for such bends in the wire, as this will ruin the efficiency of the charger in no time.
  • This may sound elemental and stupid to some, but it does happen to many people. Maybe you are simply using the wrong laptop charger by mistake, or maybe you have failed to switch on the power switch. Check both these things to be sure.
Any of these potential causes could be the reason behind your laptop charger not working. As a result of these, either the mains power lead of your charger may be damaged, or the power supply unit may be damaged, or maybe the lead itself is damaged or broken somewhere, or some circuitry inside the laptop is damaged, and not responding to the charger. It's hard to accurately tell which of these problems could be the real cause of your laptop battery not charging, without physically examining the machine.
Solutions and Answers
Now if you are well versed in computer hardware you can attempt to fix this yourself. Most people cannot do this, and it is advisable for them to visit a computer repair shop instead. They will examine the laptop charger not working problem, and suggest some suitable remedies for it. Depending on your budget, you can choose an option that suits you and simultaneously solves your problem. Here are some recommended solutions.
  • Buy a brand new charger which will definitely solve your problem of charging the laptop for a long time.
Compaq Presario CQ40 Laptop Charger
  • If you're hesitant to pay that amount, you can try and purchase a second hand laptop charger from eBay.
  • Get your's repaired and pay the repair shop the fees that they charge.
  • If your warranty is still valid, you can simply get the laptop charger replaced.
Reference: http://www.buzzle.com/articles/laptop-charger-not-working.html
Apr 25, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
Oct 31, 2010 | HP Compaq nx5000 Notebook
Charger is plugged in but when i switch on, orange light flashes then stops but laptop wont come on
the issue might be with the charger which is not supplying power or is with the charger port in the laptop itself,it might be loose or it might be completely broken...try with different working charger which is working for another same kind o laptop if you can if it turns on the laptop replace or repair the charger..if the other charger also don't work it should be the port take it to the hp store to get it repaired...
hope it works
Oct 02, 2010 | HP Compaq 6720s Notebook
My charger is not working anymore. and i cant find one that works
If the charger works on another machine, then your laptop has a faulty mainboard.
if the charger does not work on another computer then you need a new charger. Take the brand and model etc details from the bottom of the charger / power adapter a find a replacement either locally or on ebay.com for example.
if the new charger works on another machine but not on your computer, then your computer is faulty. Most likely not worth the replacement of a mainboard, I would buy a new laptop if you are outside of warranty.
you should take the laptop to a local professional to get a diagnosis and a repair estimate, as well as get your important files off from the hard drive of the laptop if needed.
Nov 03, 2009 | Toshiba Satellite A215-S5822 Laptop
New laptop charger is not allowing laptop's batther to charge
if your laptop will run off ac power and it will not work then you need a new battery if the charger is not working make sure the output voltage on the charger is 12volts and 2amps if it is not then the charger is to weak to charge the battery.
Mar 11, 2009 | HP Compaq nx9030 Notebook
Toshiba Satellite M30-832 Laptop Charger (1300724LMD0000029) Logo
124 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
