Question about Canon PIXMA iP90 Mobile Printer
Black ink won't print.
Text is printing blue and green.  I installed a new black ink cartridge but the problem still exists.
  • Anonymous Jan 15, 2009
    all my colors work fine, but the black ink won't print
  • reh9131 Jan 28, 2009
    President:
  • 8,637 Answers
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Trying to print documents, white background with black typed words. Problem I have is the printed documents have solid dark blue and solid black ink and the words don't show.
Are the ink cartridges installed in the correct colour order?
Have you printed a test page through the printer's own control panel? What was the result?
Open a new document, using the default settings. Key in some test text. Try printing. What is printed?
Jan 06, 2015 | HP Office Equipment & Supplies
Black is not printing
Try this to unclog printhead.
take out cartridge, locate the hole where ink goes trough, put a can of compressed air and blow it.
put some paper under the printhead to catch ink.
Jan 14, 2008 | HP Business Inkjet 1200dtn Printer
I put blue ink in a black cartridge and from then
Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
Compliments and wish you best of luck.
Jan 02, 2010 | Canon PIXMA iP1600 Printer
It only prints green copies, no black. Why
Needs the black ink cartridge replaced/refilled.
If this has been done, check to make sure the cartridge has been installed correctly.
Make sure the Black and Green cartridges have not been switched by mistake. Especially If your printing black text and only green shows up.
Nov 08, 2009 | Brother MFC-9440CN Laser Printer
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I have installed two new ink cartridges #80 and #70. When I try to print I get black lines across the page and some blue printing as well as the symbol of a flag shape with colored squares that are...
the cartrudge is not got detected in the printer .as click the properties of the printer go to solution center and then click the options tab and then get the cartridge detected in the printer.and then it will work.
Dec 10, 2008 | Lexmark Computers & Internet
Problem with Canon MP730
hi, i was having the exact same problem with my printer. and i also tried reinstalling the driver. after reading your post i decided to see if the printing problem occurred when i used the other colors, and it looks like it's only a problem with the black ink. i printed out a sheet with the text in red and another in blue and they came out perfectly. but the black grid that surrounded the blue text, still looked problematic.
so... that means that the black ink is the problem. i haven't tried putting in a new cartridge. did you say that your problem occurred after you put in a new black cartridge, or did you try putting in a new black cartridge and you still had the same problem?
May 06, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
old marine
old marine
