Question about Epson Stylus CX6400 All-In-One InkJet Printer
On/Off switch will not turn power off
After using the printer successfully the printer commands and the printer On/Off switch will quit working without giving any indication of trouble.
  • 97 Answers
Will turn on and not off with the same button? Try the power operation with printer disconnected from the PC. If the problem persists when in this state, it is a problem on the IC controller and is not a repairable item due to cost. Printers are cheap these days and repairing them for anything other a gear jam is not cost effective.
Posted on Jun 22, 2007
  • 102 Answers
Ok, a really brief description you got there, so the answer will be big. There is two main things you go to do. One on your PC and the other is on another person's PC. first, you got to test your printer on another PC to isolate the problem. If it worked then it's a problem in your Printer driver, uninstall reinstall or update. If it still has the same problem, then you have to do the same on your PC, uninstall your Printer Driver, reinstall then if still has the problem upgrade your software. Still not working? you have to open-up your Printer, unscrew the screws on the outside then check the board if there is a burned IC or resistor. Maybe something you can barely see. The last option is for a technician to check it. Good Luck.
Posted on Jun 18, 2007
When i turn on/off my printer,Paper Feed Roller automatically push the plain paper(A4)
hi . you should check the mechanism. there is a solenoid responsible for picking the paper up. clean the metal plate of the solenoid. it should be sticky and that cause that problem. good luck
Mar 15, 2016 | Canon PIXMA Office Equipment & Supplies
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
Dec 04, 2009 | Linksys WRT160N Wireless Router
Error8007000b
Here's a fix for Windows Vista Update Error 8007000b and it works (I tried it)
1. Open an Administrator command prompt by right clicking on Start -> All
Programs -> Accessories -> Command Prompt and selecting "Run as
Administrator" and clicking "Allow" for the elevation prompt
(or use run->cmd)
2. In the command prompt, type the command below
cd\
3. Then type fsutil resource setautoreset true c:(If your vista installation is in C: drive)
4. It should say it was done successfully
5. Reboot your system
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
Inability to online printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Epson Aculaser C1100 Printer
I am having problems connecting to a lexmark 4800 printer using wifi on one laptop. it only works through usb. uninstalling and re-installing drivers/software has no success. printer works fine on other...
check your windoes firewall and antivirus firewall .
also check ping to your network printer.
try to ping those ip if u get ping then it is ok.
check your printer and laptop gate way is same.
run this command in "run" iss "ping 192.168.15.1" ehchange your printer ip in this command.
thats it.
Nov 09, 2008 | Lexmark Office Equipment & Supplies
Cannot Install it Successfully
Restart you computer. Turn your printer off, wait 20 seconds and turn it back on again. Load up software you use to talk to the printer.
What interface are you using to connect to the printer?
Jul 17, 2008 | Star Micronics TSP400 Label Printer
Lexmark4580
Not quite sure how I did it. Think there may have been a malfunction with the power button. I have managed to use the printer successfully today. Thanks.
May 06, 2008 | Office Equipment & Supplies
Both power & feed lights flash
Information gathered: Basically the printer carrier has stalled.
Lexmark documentation states that you should turn off your printer and wait a few seconds and turn the printer back on.
Restarting the spooler will sometimes do the trick as well.
Go to start, run
type: <cmd> without <>
Command prompt will open up.
Type: net stop spooler
The spooler will say it stopped successfully.
Type net start spooler
The spooler will say it started successfully.
Hope this helps!
Jan 20, 2008 | Lexmark JetPrinter Z22 Color InkJet
Epson Stylus CX6400 All-In-One InkJet Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
