Question about Mitsubishi WS-65611 65" Rear Projection Television
Mits ws-65611 Where can I buy Nichicon Caps for my tv?
  • 133 Answers
Fryes
Posted on Jan 09, 2009
Ws-65611
you have convergence menus
Activate ……..MENU-2-1-5-9
Coarse Green Tilt
Coarse Red & Blue Tilt
the TV should have a Crosshatch or convergence signal
green done first to make it level
then blue and red to match the green
be carefull not to change any other setting other than the Tilt; because you can really mess up your convergence
if the menu adjustments dont do this for you:
you have a light box assembly inside the set that has the Red, Green and Blue Guns mounted on it: it can be mis alaigned as a whole causing what you are discribing. Also, you have a mirror that relects the guns onto the back of your screen: less likely but it could be misaligned..
Just be carefull not to touch any of the following:
wires, circuits, circuit boards, heat sinks, and especially the three Big wires that go to the 3 picture tubses... they have high voltage
the heat sinks could also be live .. Just be carefull !
make sure you have really good lighting and room to work and you should be able to fix this without a problem.
Ed
Apr 09, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi ws65611
Mitsubishi sets are notorious for leaking caps. These are the black caps labeled "Nichicon" and sometimes "Rubycon". They are easy to spot because the negative leg has what appears to be dark acid leaking down, the board has a circle of discoloring around the cap and sometimes the copper trace on the other side of the PC board is all black and contaminated. If you know what you are doing, you can remove all of these caps, clean up the board and replace with quality caps, and this usually solves the problem.
Jun 27, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Mitsubishi WS-65611
Just from what you've described it could be any number of things. One of the more common problems is the convergence Ic8c00 Stk393-110 Mits. Part # 267p155010 and the fuse 9a04... On a scale of 1 to 10 and 10 being the most difficult the task is about an 8 to replace and trace test the convergence circuit. You can however check and see if 9a04 is open, and if so, then you know where the problem is and can be more informed when asking a shop about what they charge to repair this problem. Take a VU or DMM meter set on continuity and loacte 9a04. That location number will be printed on the board right next to the component you're looking for... Next test it for continuity. If you get no reading it's open and the convergence amp is the culprit. Hope this helps. Bill
Jun 06, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Mitsubishi WS-65611 65" Rear Projection Television Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
