Question about Nakajima AE-710 Typewriter
Typewriter just beeps
Peeps when you first turn typewriter on if ribbon carrier is at left frame  starts beeping continually.
  • lwright66 Feb 04, 2009
    I have a Nakajima AE-710. When I turn on machine the print wheel goes to the left hand side and stops and just keeps beeping. cannot type.
    No stuck keys. Help!
    Scholar:
  • 75 Answers
Very common problem, The print wheel homing sensore weirs broke off. you need to take off the ribbon deck. pull weirs from the white plastic sleeve that runs from carrier to main board. fined 3 weirs grouped together ( red, black,green) 1 or more of them are cracked in side the casing or have broke in 1/2. need to resolder them together little tough to do the 1st time. a bunch of sen sores came out with to hard of a weir making them brake premacherly
Posted on Jan 24, 2009
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Turn on and it has a continuous beep
Most typewriters have a "power on system test" or POST routine. Beeping means that it fails the test. With the power off, try moving the carriage all the way to the left and turn it on. Some typewriters, if the carriage is not right over the left sensor, will fail the POST. Most typewriters will check things like, "Is there a ribbon installed?" "Does the Daisy Wheel home?" and will move the carriage left to right to make sure that the sensors recognize the left and right limits. There are other checks of course, but those are the ones that are easily fixable.
Apr 14, 2014 | Swintec 2640 Electronic Typewriter
Brothers ax
Turn off the typewriter, open the top-cover and inspect the area around the carrier for any damage or foreign objects.
2. Move the carrier towards the center of the machine.
a. When moving the carrier manually, it should be difficult to move, butit will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connectedproperly.
3. Remove the ribbon and inspect the cartridge for damage. Turn the colored knob on the left side of the cartridge to remove any slack from the ribbon.
4. Check the correction tape to insure that it has not become tangled ordamaged.
5. Close the top-cover and restore power to the machine.
If the problem persists, your machine may require service.
Dec 12, 2013 | Brother EM-430 Typewriter
My typewriter is beeping ...
Beeping means a problem, printwheel not on, ribbon out or jamed, carrier not moving, maybe against margin turn on and off ans dee what happens. If beep persist, possible bad carrier or board.
Oct 06, 2013 | Brother Office Equipment & Supplies
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com/service/default.aspx
May 08, 2013 | Brother EM-530 Typewriter
Continuous beep at start up. Nothin works except cap lock light so codes or margins can't be changes.
Doesn't sound good. Be sure the upper cover is fully closed, check for debris in the carrier area, give the silver shaft that the carrier rides on a shot of WD40, be sure the ribbon and L/O are properly installed and the print wheel dosen't have broken spokes.
DickyO
Apr 12, 2011 | Nakajima AE-800 Typewriter
Brand new typewriter. Set up according to
When turned on the carrier must move to the left side frame, where it seneses the LEFT limit, then moves towards the right and parks at the Left Margin Position. Your problem sounds like something is interfering with the carrier movement to the LEFT limit (could be packaging). Turn the power OFF. Manually move the carrier to the RHGHT. Look inside the machine on the left side to check for foreign materials. Also check that the ribbon, correction lift-off tape, and printwheel are installed properly. GOOD LUCK!
Dec 29, 2009 | Brother EM-630 Typewriter
WW6 will not type.
Check to be sure the printwheel is properly installed and that there isn't any debris in the printwheel area. DickyO
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
Beeping
It most likely beeping because it cannot make its resetting movement. That is,it cannot "find-out" where its left margin is. There may be something hindering the actual movement of the print carrier. Check inside the typewriter by lifting up the top cover and move the print unit by hand. It should be able to move from the left to right-hand side of the typewriter unhindered. The shaft that the print unit moves on should be clean and it may have gathered dust etc,so give it a wipe with a clean cloth (lint free) with a small drop of light oil on it.. Replace the top cover and switch on the machine
Nov 05, 2007 | Nakajima AE-740 Typewriter
Beeps 6 times, lights blink
The prinwheel sensor is likely the issue.  Move the carrier to the right, on the left side of th carrier toward the rear of the machine there should be a small black "flag" sticking out of the carrier.  this should move freely in and out if it is not there or does not move the machine cannot detect the printwheel the sensor will need to be replaced.
  You ca also check for debri down in the area where the printwheel sits.
Sep 11, 2007 | Lexmark Wheelwriter 1000 Typewriter
Nakajima AE-710 Typewriter Logo
344 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
