Pictures have lines running down them...
Every time I print out a picture,  vertical lines appear on it. It seems that they are from the rollers of the printer. But this has only just started happening. How can I fix this problem?
  • tristam_cone Jan 08, 2009
    Thanks for getting back to me so quickly. Unfortunately, I don't think that the roller would have worn out as the printer is relatively new and was only purchased 6 months ago. Could it be anything else?
    Guru:
  • 829 Answers
Hi It seems your teflon roller has worn out , Get it replaced and should work fine.
Posted on Jan 08, 2009
  • Milind Shetti
    Milind Shetti Jan 08, 2009
    Hi , I have some questions for you then , How many prints do you print per day and whats the printer Make and Model.
C5800 printing vertical lines through pictures
The thin lines are caused by a worn out drum. Remove each drum in turn and look at the surface. It maybe hard to see the scratches and if so then send solid blocks of the primary colours one at a time and that will prove which drum is at fault.
Oct 28, 2017 | OKI C5800Ldn Led Printer
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
Lines are appearing on my pictures I print
calibrate it. should be a utility in the printer software
www.aa1consulting.com
Jul 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Using glossy paper but lines appear
try and clean the rollers by running system checks on the printer software or you may be running out of ink, try replacing your cartridges
Jul 20, 2009 | HP Office Equipment & Supplies
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Verticlel lines appear when colorprinting photos
There may be multiple reasons why your pictures and printed pages have unexpected vertical or horizontal lines. To resolve this problem,
http://www.kodak.com/global/en/service/repair/troubleshooting/aio-troubleshooting.jhtml?pq-path=10355
Within the Link, select Print quality, then Unexpected vertical or horizontal lines (banding).
Nov 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
111 people viewed this question
jasbo
jasbo
