Question about Akai LCT2715 27 in. LCD Television
Building power outage caused TV not to work
Speaking on behalf of my neighbor, he has a an Akai HD TV that will no longer turn on, the power switch is always on and just remotely turned on and off. The other night the buildings power went out and now the TV will not work at all. Tried switching the TV power switch on and off and nothing happens,any suggestions?
  • Anonymous Jan 20, 2009
    My parents dropped off this TV to my house as a gift for my living room, When I plugged it in there was a small spark from the outlet. When I tryed to turn the TV on it wouldt. So yup same problem
    Novelist:
  • 152 Answers
Hello, your freinds tv has a power supply issue, it is the part that accepts incoming outlet voltages. replacing the power supply may solve this issue it is not garanteed becuase the spike or drop in voltage may have cuased other truoble in the other circut boards, the power supply couldnt handle the imediate drop in voltage cuased by a power faliure when you try to turn it back on the circut is detecting that it is not working properly so it will cause this safety shutdown it is protecting your tv from further damage.
since your area or building had the power outage this may have cuased the power supply fualt. check the voltage test points to make sure they are correct. exchanging it wouldn't hurt at this point. best bet is to get a service manual for it and be extra careful do not touch internal parts they still have stored voltages if your not electronically inclined or dont have any electronic skillz, have a service center come out and check it for you.
good luck to you guys, hope this helps
Posted on Jan 08, 2009
  • 2,322 Answers
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
Feb 18, 2011 | Akai PDP6065TA 60 in. Plasma TV
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Won't boot up
Emachines are notorious for motherboards and power supplies frying after a power outage. Why? Even after 10 years of working on desktops from all manufacturers... this eludes me.
1)The power switching chip or chipset usually goes first. My best guess is be casue the power supplies in these desktops are VERY inexpensive. IT's amazing if they last longer than 1 year.
Replace power supply.. if doesn't boot still... replace motherboard.
2) If i'm waaay off and you get a boot screen or emachine logo.. but no windows logo... then hard drive crashed or file system got shot...
Replace hard disk and reinstall windows.. contact data recovery specialist. DYI data recovery .. causes more data loss... speaking from experience.
Nov 03, 2008 | Microsoft Xbox 360 Console
Akai pdp5016h 50 inch
Thats a real tough call on your problem as the set acts like its working normal and then gives out. It could be any number of things, but mostlikely somthing is drawing too much power causing a protection fault hence the power off. These types of problems are very hard to diagnose as the stuff your looking at looks good, its not until it warms up (even being a few seconds or so) that they go bad. You can allways put a meter on the VA and VS to see if there is a flucuation in voltage or even a spike and that could tell you possibly which board is the culpret, but the best is to replace and not repair as switching supplys can be a pain.
Apr 19, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Akai LCT 32"
Do you still have this TV?Sounds to me like a bad capacitor,or two.I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Jan 03, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
AKAI 55" Rear Projection TV won't turn on.
the 3d effect tells me that your convergence ic's have blowned. standard for these sets.. not to much of a difficult repair. repair them all the time..
Dec 13, 2007 | Akai PT5598HD 55" Rear Projection...
TV does not turn on
it will cost around 400 to fix. its the power supply. it happened to every akia like this and astar 26 lcd. just a crappy tv. i would have to say they all lasted about 1 year when this started. i sold these tv s for a while at my work.
Oct 14, 2007 | Akai LCT2660 26 in. HD-Ready LCD...
Power outage caused child lock, 2729 model tv
I'm guessing what you have there is an Akai CFT2791 made by Samsung? And a CFT2729 is not a good model number. You will need to get into the menu and then sub menus to change or turn off the child lock feature. The procedure is well described in the owner's manual and I have the manual. You can email me privately I'll send it to you... premtech@willapabay.org Bill
Jun 03, 2007 | Akai CF2791 27" TV
Need help with TV
take it apart and see if all the cables are seated properly, and check the panel voltages could be one of the boards
Aug 04, 2006 | Akai LCT2660 26 in. HD-Ready LCD...
Akai LCT2715 27 in. LCD Television Logo
276 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
