Question about Dell XPS™ 600 PC Desktop
Dell XPS fan come on but nothing else powers up. I hear a beeping noise coming from the PC.
  • Prashant Bharadwaj
    Prashant Bharadwaj May 11, 2010
    how many beeps do you hear?
    Have you installed any Add-on Graphic Card?
  • 89 Answers
Most likly a hardware issue i would recomend taking it into a shop what is your computer experience?
Posted on Jan 08, 2009
Dell VOSTRO 460 beeps during startup and will not startup.
many times if the fan over the cpu chip on the motherboard fails to run or blow, an beeping alarm will begin and PC will not start. the cpu has to be kept cool so if fan fails the startup is stopped. have found lose wire connections from fan to motherboard terminal, or power supply may be blown, try checking those first. if nothing lose then wiggle those wires to see if the fan starts.
Jan 30, 2014 | Dell XPS 200 PC Desktop
Dell XPS PC Desktops Beep 2 short beeps then turns off
Here is a link to your computer's service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_xps_desktop/xps-400_Service%20Manual_en-us.pdf
There is a section on Advanced trouble shooting which details Beep codes and LED diagnostic codes.
Feb 13, 2013 | Dell XPS Computers & Internet
My Dell XPS 200 will not turn on.
Have you checked to see if your power supply is still good, or the power supply connection to the motherboard is good?
Sep 14, 2012 | Dell XPS 200 PC Desktop
Dell xps demension. When I turn on the power botton fan comes on at a really fast speed but nothing else comes on. Doesn't load anything??
A cool heatsink points to a CPU failure, as the CPU is not processing data. Replacing the CPU at first would eliminate this, however, the CPU is unlikely to fail first unless it had been severely overheated, more likely that the board has developed a fault.
If you are however getting no beeps on start up, this does look like the CPU is the culprit
Jan 18, 2011 | Dell XPS 200 PC Desktop
The computer isn't coming on the power cable is plugged in the green light is blinking but nothing else is happening
Do you hear fan starting noise? If you dont hear any noise most probably you need new power supply.
you can buy cheap power supply from www.aria.co.uk
if you hear the fan noise!
Does you motherboard starting with POST (a beep noise).
if you dont hear. well you need a new motherboard which should be compatible with your other peripherals.
if you hear a beep noise! Most probably your operating system is corrupted. (Boot file corrupted)
in this case you may have to install new operating system.
Thank you
if you got any problem let me know
somindradilruk@gmail.com
Sep 03, 2010 | HP Pavilion a705w PC Desktop
Dell XPS 600 beeping noice
there are 2 things that can cause that, memory failure, or mother board, cheeper route to go would be replace your memory first, and see if that corrects the problem, if not then, check anything new you installed inside such as video card, lan cards, of something like that, if that doesn't work you need to have it looked at and possibly the mother board replaced,
Jun 22, 2009 | Dell XPS™ 600 PC Desktop
Dell XPS M1530 Laptop temperature is getting hot
Do you feel air coming out out the vent? it might be clogged with dust. so blow it out.
Jun 17, 2009 | Dell XPS M1530 Laptop
XPS 600 - Six Beeps No Boot
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
http://www.computerhope.com/beep.htm
Jan 22, 2009 | Dell XPS™ 600 PC Desktop
Dell XPS 730 - Brand New - No display - Fan Loud
check if u r able to open the optical drive if its opening then power supply is gone bad or else get mobo an power supply replace
Dec 13, 2008 | Computers & Internet
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Dell XPS™ 600 PC Desktop Logo
224 people viewed this question
Alun Cox
