Question about Compaq Presario C700T Notebook
NO VGA INPUT SIGNAL
I HAVE A COMPAQ PRESARIO. eVERYTIME I TURN MY COMPUTER ON IT SAYS ''NO VGA INPUT SIGNAL'' AND I DONT KNOW WHAT TO DO BECAuse it goes to sleep afterwatrds and we bought a new video and i guess we put it in right but we dont know because it still does the same thing. i also dont know whether the mother board has a video card or intergrated video. really i dont know what intergrated vidoe is or where the motherboard might be and how do i find out if it has a video card or intergrated video. we really need our computer. please help. also be very detsiled. add pics if you can. also how do i found out what series computer i have?
  • pristineacc Apr 15, 2009
    Did you ever figure out what was wrong? I have the same problem with my desktop right now.
Hi im aleli can you give me a driver of c700 video controller,, tnx
Posted on Jan 17, 2009
I have a compaq presario SR2020NX 2005 and there been like around 3 years that I have not been using it, then I decided to turn it on ( started beeping) well I brought everything new ( power-supply...
Rita...Unplug the computer, take your BIOS battery out (make a note of which side is facing up!), wait 15 minutes, replace the battery (make sure it goes in the same way it came out, do not reverse polarity by accident) and reboot. Does that help? If you had this work done on your computer by a service, contact them with this problem. They should have tested the unit before sending back to you.
Aug 10, 2013 | Compaq Presario SR2000 Desktop PC series...
What cable do i need to connect my pannasonic viera px-p42g20b to my compaq presario v6642ea
Hi gmickg,
From what i can see your compaq presario has both hdmi and vga outputs the panasonic viera you have both a vga and hdmi input. Therefore you can use both a vga lead or a hdmi lead. Hdmi also outputs audio therefore it is probably a better choice.
Regards,
K
Mar 30, 2011 | Panasonic Computers & Internet
How can i connect my compaq presario cq60-215dx to my tv?
In most cases the answer is "YOU CAN'T DO THAT".
The output from a computer is not a signal that a regular TV can interpret as an image, unless your TV has an input similar to a computer's VGA or DVI port AND the TV's manual says that you can do that. Otherwise, you're out of luck
Mar 27, 2010 | Compaq Presario CQ60-220US PC Laptop
Green light comes on and the fan but monitor will not
Hello.
Could be the monitor or your Presario's VGA card. Swap the monitor with another system to see where the problem lies. If another monitor works on your system , it's your monitor. If another monitor doesn't work, then the problem is the VGA card.
Hope this helps.
Nov 10, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Can I go from VGA to SVGA?
If the question is can I convert my composite video output to a super video input then the answer is NO,
The composite is coaxial (2 wires) the S-Video uses 4pins and there is no S-Video output on a Presario 1200 laptop.
You can however use a Multi-AV SCART adaptors with Input/Output signal switch where you plug in the composite video output into the top video and 3.5 mm jack stereo audio into the mono audio connections on top.( via a stereo to mono cable)
http://upload.wikimedia.org/wikipedia/en/thumb/a/a7/Multiconnector-scart-chti.jpg/200px-Multiconnector-scart-chti.jpg
Hope this is the answer you are looking for !
Sep 27, 2009 | Compaq Presario 1200XL103 (155726-163) PC...
Monitor malfunction, says VGA Input: No Signal and goes to sleep
from what you have described it appears that the onboard video might have malfunctioned,there is no way to replace it, you can however go buy a video card from your nearest computer retailer. you just want to make sure it is compatible with your machine. on another note from what your saying the keyboard is donig i would be wary about spending to much $$ because it could also be your motherboard
Apr 23, 2009 | Computers & Internet
Screen says no signal input.
Did you try the screen with another computer?
Did you try the computer with another screen?
Do you ear the fan running when you start?
if yes the graphis card might be dead. if you don't have a graphic card (on the mother board) CPU dead or mother board any way ...bad signs
Dec 23, 2008 | Compaq Presario 5000 PC Desktop
When I try to turn on my computer the monitor reads: VGA input: no input signal
The monitor is telling you that it does not see the computer. First, remove the monitor cable from the back of the computer, check for bent pins on the connector and replug in the connector.
If that doesn't work, try swapping to a different monitor to see if it sees the system. If this works, you have a bad monitor or monitor cable.
If that doesn't work, open up the computer remove the video card, clean any dust from around the card and socket and replug the video card.
If these ideas don't work,get back to me and we'll go from there.
Have a good day!
Ron
Dec 10, 2008 | HP Compaq Presario SR2011WM PC Desktop
If it was your video card, you would have no picture at all. Try to boot in safe mode and do into your options and make sure your hibernation is not on. Only other thing I can think of, it could be *********** board.
Nov 29, 2008 | HP Compaq Presario SR2011WM PC Desktop
How to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Jul 08, 2008 | Computers & Internet
Compaq Presario C700T Notebook Logo
554 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
