Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Motor goes on and off briefly at regular intervals
Hi - Our Kenmore Progressive canister vacuum is switching on and off. When it is plugged in the motor cuts in and out quickly and constantly. The handheld part continues to work even when the motor in the canister is off (without suction, of course). Any thoughts?
  • Anonymous Feb 11, 2009
    I have a Kenmore Progressive canister vacuum that's 2 1/2 years old. When I use the Powermate to vacuum the carpet, the suction power cuts in and out intermittently.
  • roothedog Feb 12, 2009
    My vacuum goes off after a minute or so of running.  Sometimes it won't even turn on.  Any suggestions??  This vacuum is also only 2 years old.
  • 1,673 Answers
Sounds like you may have a bad or loose connection, could be one of wires in the hose to the handle harness or the harness itself may be causing the problem. Also be the motor or relay causing a problem.
Posted on Jan 08, 2009
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Kenmore Progressive Vacuum-Need to replace plug
Splice a new plug, but get a good one. Tough with a scew to hold it together
  • White wire goes on the silver terminal.
  • Black wire goes on the gold terminal.
  • Green (or bare ground) wire goes on the green terminal
More here:
Mar 26, 2009 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore 23513 canister vacuum won't turn off
Is there two switches for the unit, one for the handle (pick up unit) and brush assembly, and one for the vacuum motor? If so it seems that the handle unit is o.k. but the problem may be the switch to the vacuum motor. I would suggest testing the vacuum motor switch with an ohm meter for continuity through the switch. If its at fault replace it. You can probably purchase one from Sears or maybe Radio Shack.
Good Luck!
p.s. do not work on vacuum if plugged in.
Apr 06, 2008 | Kenmore 23513 Progressive Bagged Canister...
Vacuum won't come on
The switch in the hose maybe bad, motor problem, or some of these cannisters have a relay mounted by the motor, it may be bad.
Mar 16, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
254 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
