Question about Uniden TRU8885-2 Cordless Phone
Gives wrong time and day
The time and day is wrong and I dont know how to reset it.
    Scholar:
  • 47 Answers
This is from the Manual. If you want the whole manual, at the end of the instructions, there ia a link to the manual.
Setting Day and Time
Day & Time sets the day and time of your display.
1) Enter the Global Setup menu, and then the Day & Time
submenu option (see "Entering the Menu" on
page 17). Image is for the base.(Here is how)
Entering the Menu
1) In standby mode, press the MENU soft key.
2) Use volume up/down to move the pointer to a desired
main menu (DirectLink Mode, Room Monitor, Handset
Setup, Base Setup, Answ. Setup, Global Setup, and
Deregister HS).
3) Press the OK soft key to select the desired main menu.
To return to the previous screen, press the BACK soft
key.
4) Use volume up/down to select a desired submenu and
then press the OK soft key to enter.
5) In the submenu option, use volume up/down to select
an item. Press the OK soft key to confirm your
selection. For detailed instructions, see the following
sections for the desired submenu option. To return to
the previous screen, press the BACK soft key.
6) To exit the menu, press end on the handset or cid/exit on the base.
2) Press volume up/down to select the day of the week,
and then the → soft key.
3) Press volume up/down to set hour, and then press the → soft key.
4) Press volume up/down to set minute, and then press the → soft key.
5) Press volume up/down to choose A M or P M, and then press the SAVE soft key. You
will hear a confirmation tone.
http://www.uniden.com/pdf/TRU8885-2om.pdf
Posted on Jan 09, 2009
Hi, I have bought this G1 from Ebay, dont know what is wrong with it. when turn on it vibrates & screen remain blueish black, I tried to Factory reset it. everytime you hard reset it, it gives...
HOpe you did the hard reset by pressing and holding home +power and then alt+w .
Does pressing and holding camera and power gives you the bootloader ( Hboot ) screen . IF yes , try reset from there .
ALso CLick HERE for more details .
Aug 06, 2011 | HTC G1
My Model # is 27957FE 1-A Dont know how to reset
To set the time and date, start at the base unit. Then press the Flash/Program until Set Day appears on the display. Press the Review or Next button to select the day of the week. Then press Flash/Program again until SetTime appears in the display. Type in the time (hour (two digits) then minute (again two digits)) with the keypad number buttons. Then press Review or Next to select AM/PM. Press Flash/Program to store the information.
Please note that if you have Caller ID, the time and day transmitted with the caller ID information from your phone company will override the day and time you have set.
The manual is available here: http://www.home-electronics.net/USER-GUIDES/27957_DOM_ES_CL_IB.pdf . See page 15 for this.
I hope this helps.
Jun 01, 2011 | Thomson GE-28115FE1 Cordless Phone
I have a new nokia E63 When I type a W it gives
Hello!
I have good news and bad news, I know whats wrong with your phone, however at the moment i dont know how to fix it :(
The Nokia E63 has a QWERTY keypad. However, if the firmware was built in a different place than the phone itself (did you buy your phone abroad?) its possible your phone may have the firmaware of an AZERTY keypad.
If you think of each key having a number (1=q 2=w 3=e 4=r etc along the keyboard) Your phones firmware should recognise 1 and being ''Q'', and therefore display it .. however, your phone is recognising 1 as being ''A'' and so on, which is what is causing your problem.
The best thing you could do is to do a complete restore/factory reset, remove your memory card (if you have one) and go back onto the nokia website and reinstall the latest software. However, do NOT restore backups after updating. Otherwise, i thinks its a trip to the ol' Nokia Hospital i'm afraid!
Hope you find a solution soon.
Jul 04, 2010 | Nokia E63 Cell Phone
Passcode on ipod forgotten
a reset is needed, whenever i preformed a reset on my iphone all my memory got deleted so i dont know if you want to try this. But press the home key ( the white square button) and the power switch at the same time and hold. If it works it should ask you to plug it into a computer with itunes. Hope this helps!
Mar 10, 2010 | Apple iPod touch
My gas pedal gives me a lot more resistance than it used to.
try to spray some w-D 40 on the cable while some one works the pedal
May 11, 2009 | 1997 Chevrolet Malibu
Remote that gives outside temp does not work put in new batteries, still does not work!
Pull the batteries out of the clock, wait a minute, and then put them back in. That will reset the link between the two. The temperature should be OK in just a few minutes. The clock will read the wrong time and date until it resets during the night. The next day, all will be well.
Apr 20, 2009 | La Crosse Radio Controlled Atomic Clock
Magellan roadmate 2000 will not turn on!!! help please!!!!
You have to reset the unit with the slid switch and reset button on the teft side under the rubber cover
see your manual.
Dec 27, 2008 | Magellan RoadMate 2000 GPS Receiver
Wrong arrival time?
And you are sure that the unit is set to the correct time zone?
Nov 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Uniden TRU8885-2 Cordless Phone Logo
195 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
