Question about Toshiba CF27H50 TV
Again, I don't know how to find the AV mode.
Hi
I have an old Toshiba Model nr: cf27h50
I had to get a Digital TV Converter the other day adn when I am trying to connect it the manual for the converter tells me to: Turn on the tv and switch it to external AV mode, and then I will see a picture coming from the box. My problem is, I cant find how to get it to AV mode. I ahve connected so many things through my reciever with this TV, so i did not think it was going to be that hard to connect this one. Again, I don't know how to find the AV mode. Anyone who can help?
  • Madelaine7 Feb 09, 2009
    Jim
    That worked for me too (a couple of days after I posted this thread hahhahaha) I figured it out...but i agree about the vcr, i did not even hook it up, i could not figure out how to make it all work together....
  • John Bolton May 11, 2010
    You need to finish telling me what is wrong.
  • 86 Answers
The converter that you have will only work thru the tv cabel. If you have a s-video you can use that for the picture but you still need to use the red and white audio cables for the sound. This converter will not give you HD but it will make the picture you recieve better. The picture will play thru your TV on chanel 3 or 4 and you need to use the remote that came with it to change stations. Hope this helps.
Posted on Feb 11, 2009
Madelaine,
I had the same problem just now trying to get my Tivax STB-T8 converter to work the 1st time I tried to set it up. I couldn't see anything on the TV or VCR that indicated what "external AV mode" is or if either unit had it.
The ONLY change I made -- on both the TV & the converter box -- was to switch the "ch 3 or ch 4" from ch 4 to ch 3. (I'd always used my TV & VCR on the ch 4 setting.) Once I did that, I got the menu & was able to proceed w/the next steps & it appears to work.
One caveat: I have yet to figure how the VCR works in all of this. I have it hooked up in the mix, but have yet to attempt to have both the VCR & TV on. (Maybe I don't need to do that anymore -- I may have done that cuz my external antenna was hooked up to the VCR & then the VCR to the TV & that's how i got a decent signal.)
I have no clue as to what the difference is betw ch 3 & ch 4 or if it would solve your seemingly similar problem on your particular TV & converter combination, but it would be worth giving it a shot.
If it works, I'd be interested to hear your feedback.
Fingers crossed -- Jim
Posted on Feb 09, 2009
My TV sanyo model #d925204 I can't change the
Hi. Try the local channel up/down buttons. Go all the way down , below nr 1. You'l probably find the AV inputs.
Oct 09, 2014 | Televison & Video
Tv/video
can you tell me the brand and model of the new remote. You already gave the tv model, so the remote details are all I need.
Jun 22, 2008 | Daewoo Televison & Video
Does my toshiba 50h82 have an internal digital converter?
I doubt the model as old as it is will work without a converter.
Oct 25, 2012 | Toshiba 57H82 57" Rear Projection...
I have a Toshiba CF27H50 that just stated losing the picture after about an hour of viewing. After an hour, it starts to flicker and then the picture just is lost and it just goes to black/snow screen and...
This is a common symptom of tuner trouble. A common problem is bad solder connections inside. As the set warms up, small cracks on joints from the tuner circuit board to its metal case can cause the trouble you describe. If you tap on the TV or wiggle the connector where the antenna or cable line goes, the picture will sometimes pop back in if this is the case. It's also possible the tuner has parts that quit working as they warm up. The only way to know for sure is to remove the tuner, check over the connections, repair any that are iffy, and see if the trouble continues. This is not a repair for a do-it-yourselfer, though, because of the soldering involved.
If the trouble isn't bad connections in the tuner, there's not much you can do. I've checked the parts sources I use. The original Toshiba part is no longer available and I haven't found any replacement. If you're using a cable box or other video source, you can keep using the TV just for its AV inputs and not worry about the tuner any more. Otherwise, given repair labor cost and lack of parts, it's probably more economical to replace this TV instead of trying to repair it.
Jul 22, 2011 | Toshiba CF27H50 TV
No picture
just an idea the t.v. is 10 years old ok. Now look at the back can you see inside if so chances are there is a build up of dust which makes a great t.v. wrecker. So vacuum the dust out and see if that helps.
Jul 23, 2009 | Toshiba CF27H50 TV
Old tv, digital converter and dvd hook up?
connect the converter in connector to the antenna.
connect the converter out to the dvd in, and the dvd out to the tv in.
Jun 12, 2009 | Televison & Video
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
Toshiba CF27H50 cannot switch from TV to Cable
Have you tried pressing the cable or TV buttons on the remote?
I hope this solution is helpful.
Feb 13, 2009 | Toshiba CF27H50 TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Jvc 32220 and digital converter box
Please mention model number make of the digital receiver and 3 modes of the tv:
Jul 07, 2008 | JVC AV-32260 32" TV
Televison & Video Logo
623 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
