Question about HP OfficeJet 7410 All-In-One InkJet Printer
During unjamming some paper, the "belt" in my HP 7410 broke. Can this be replaced?
  • ftlion May 11, 2010
    Paper feeds on the 7410 are wheels that turn on a central bar, not belts... Are you referring to the mechanism that moves the ink cartridges back and forth? I have had some difficulty in getting repair support from HP, but I have found that many parts are interchangeable with similar models and many can be found in thrift shops or secondhand for cheap (under $20) that may have compatible sections. It may also be possible to improvise a solution depending on the part in question. Can you post a picture of the broken item?
  • 300 Answers
You should be able to find the part here after you locate the original part number. Hope this helps. Please remember to rate this information.
Thanks
Posted on Jan 08, 2009
Paper jam HP officejet 7410
If it shows where the jam is go there. Open the cover and remove paper.
Aug 24, 2013 | HP OfficeJet 7410 All-In-One InkJet...
I have a 7410 hp office jet that broke when i tried to replace the ink cartidge. a little tab broke off and went through the back of the curcuit paper thing. this has had very light use. I have seen many...
Yes, there many complaints of the same thing, once that ribbon cable is torn, the only repair is a new carriage assembly, if you can find a new one it will cost more than a new printer.
Dec 29, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
My hp 7410 pulls multiple sheets at one time I
remove paper and try to blow thru the papers so they a loosen from each sheets...then put it back...do a test print.....
Oct 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
7410 HP MFC Shows no power.
If you mean that the power light isn't on, but the screen is stuck in boot-up mode, try this partial soltion; it's worked for nearly everone who's tried it. It's in reference to the officejet 7410 all-in-on, but I think it's worked for other machines. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
(It's interesting that the majority of posts with this issue have occured on numerous sites during the last two months).
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jam in a HP 7210
there is a door at the back of the printer , open the door and remove the paper
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 Paper Feeds in Crooked
The paper size in the feeder and the paper size in your printing properties have to match.
I.e. if your printing format says "letter size" and in your feeder is legal or A4 paper you will get this error.
Please reply if this does not help.
Dec 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 All in One
Try this: it's worked for nearly everone who's tried it. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
(It's interesting that with the exception of the original post, this issue is suddendly appearing on numerous sites. Nearly all of the posts occured during the last two months)
Aug 14, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
