Question about Philips RC2573 Remote Control
Philips RC 144 Remote Control code for VIZIO TV ?
I can not program the remote code to my VIZIO HDTV. trying 0891,0912 and 1783 in the manual but none of it work. anyone havethe code for it? Thanks.
SOURCE: Remote Control code to work TV
NEED A CODE FOR MAGNAVOX REMOTE TO
A TOSCHIBA TV
Posted on May 02, 2008
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
Posted on Jun 13, 2008
aprmaejun
  • 97 Answers
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
SOURCE: i lost my manuals to my philips universal remote how do i program it wthoout using the code
buy another one
Posted on Oct 02, 2008
SOURCE: Need codes for Philips Universal Remote model
I found the correct code by alot of trial and error and going through every number from 000 to 999 to find the correct code.
Posted on Mar 07, 2009
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
We gave lost the remote for our Vizio 42" HDTV.
By manual I guess you mean the buttons on the TV and not switching the actual cables. my recommendation is to get a good new universal remote. My personal preference for my Vizio TV is the Logitech 650. Just know that you program it on a computer. It controls up to 6 devices (TV, DVD, Cable box, audio and more), is easy to program with no codes to enter. I am sure it is easier to get then a new Vizio remote though a little pricey at $60.
Hope this helps,
Cullen
May 19, 2011 | Vizio 42 in. LCD TV
I need the universal codes for my verizon fios remote, otherwise another recommendation of a universal remote that will operate my tv.
Setting up the Philips RC 144 remote if the remote codes are invalid or unknown If you do not know the remote codes for a device, or if you've tried all the listed remote codes for your device and none of them work, you can search for the correct remote code by following the steps below.
Note: These steps only apply to the Philips RC 144 Remote Control. If this is not the make and model of your remote, go to the supported remote control models page and find the instructions for your specific remote control.
Searching for a Device Code
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
    The mode buttons blink twice.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of the Play button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
  7. Note:
    There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
    If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Feb 28, 2011 | Apex Digital LD4088 LCD TV
None of the emerson codes work with my Philips remote
point the remote at the TV while it is on and press the ON/OFF switch for 2-5 seconds when the TV shuts off..... that is the correct code, then lock it in....!!
Mar 27, 2009 | Televison & Video
Fios code for Winbook TV
If you do not know the device codes for a device, or if you've tried all the listed device codes for your device and none of them work, you can search for the correct device code by following the steps below.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of thePlay button.
  7. Note:
Feb 11, 2009 | Zenith ZN-501S Remote Control
Vizio Code for Philips Universal Remote
Think 0002 will work. If not a GOLDSTAR code should work,
try them.
Oct 25, 2008 | Vizio L32 32 in. LCD HDTV
I am trying to program a new remote and i need my remote code to program the tv can you find the code for magnavox msd513f
Not sure your MSD513F is not listed, and dont know your chassis # so here is what I can offer with what you gave me from the manuals
FOR THE
51MP392H/17
PHILIPS phone # 1-800-432-8542
Universal remote control - RC2018/1
Universal RC managing TV and peripherals
from the parts manual
Cabinet & Accessory Parts
REMOTE Transmitter, RC2061/01 . . . . . . . 3128 147 14611
Sep 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Finding remote code to control my vizio tv
In my Vizio manual it says to try 1758 or 0178. I tried both and the 0178 worked for my rc-681m remote
Nov 25, 2007 | Vizio GV42L 42 in. LCD Television
Philips RC2573 Remote Control Logo
342 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
