Toshiba Replacement Projector Bulb Projector Lamp for TDP-D2 Logo
Posted on Jan 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bulb Replacement I have replaced an old LCD bulb in my Toshiba TLP S10 projector but, I cannot get the machine to reset the lamp timer. I have followed the instructions provided by the lamp manufactor however, the machine continues to indicate that the bulb is too hot.
  • Anonymous Mar 21, 2014
    trying to reset the lamp hours, we replaced the lamps but the timer still shows the previous hour usage. some suggestions specify to use the power switch but the tlp xe30 does not have a main power switch.
procom office solutions
Level 2:
  • Expert 93 Answers
  • Posted on Feb 09, 2009
Expert
Level 2:
Answers
93
Questions
0
Helped
59865
Points
157
The bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Reset the lamp timer TLP560
can anyone help me to reset my toshiba tlp 560 lamp
there must be a command or conbination of buttons to do this
best regards
Tlp560 service manual
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
How to reset the panasonic PT-L702ES LCD PROJECTOR after changing it bulb ET-LA702
How to reset timer on PT-L702E LCD PROJECTOR:1. Power on the projector and go into the menu
2. Go to OPTIONS > LAMP TIMER
3. Press and Hold ENTER for at least 2sec - message will change to something like 'Power Off to reset timer'
4. Press POWER to power off projector
5. Power projector back on
The timer has now been reset to Zero Hours
Enjoy!
Reset lamp timer
If you go into the info menu you should see lamp hour meter, should be option there to reset it.
only do so if you have put in a new bulb as bulbs can explode if they go over the hour usage time.
Please dont forget to vote this answer was helpful
Many thanks
What is wrong with my tlp s10 it gives the entire picture a blue tint the lamp has done 2700 do I need a new bulb
Check the Video cable that feeds the projector, could be a broken cable or a pin bent -worst case the connector on the projector has broken.
Try the VGA cable on your computer screen.
The lamp does not need replaceing, the lamp emmits white light only.
1helpful
How to find remianing bulb life on Toshiba tlp411u data projector
go into the menu while it's on and it's under settings- lamp timer.
Toshiba lcd projectors tlp xc 2500
Verify "Key Lock" function is not enabled
28helpful
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Problem with image from LCD
No, If the problem comes with connecting the signal, then it could be RGB.
if this is coming with all time then check LCD panels and Fly-eye lens.
Last thing is lamp unit.
viren
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
