Question about HP PSC 2210 All-In-One InkJet Printer
Paper feed Paper is not feeding, consequently printer head is staying "stuck" on right side making grinding noise. (Printer head does move across upon power up) Thanks
  • Anonymous Mar 25, 2014
    mis feed of paper
  • 883 Answers
Sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Posted on Jun 02, 2007
SOURCE:
I was in the process of making copies, when my Epson RX700 suddenly made a loud grinding noise. It then stopped working and displayed an error message: Scanner error occurred...Please see...
There are two drives in the printer. One moves the print head (cartridge) back and forth across the paper. Check to see if the "rubber band" drive belt is slipping or broken off. There is also a roller motor which feeds the paper. This has nylon gears which can make a grinding sound if one of the gears gets stuck. Make sure there are no pieces of paper stuck in the gears.
Mar 06, 2011 | Office Equipment & Supplies
It's says there is a paper jam and there isn't, then the ink cartriages keep popping up and makes loud noise...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck
Dec 10, 2009 | Dell 948 All-In-One InkJet Printer
Canon PIXMA MP240 scanner problems (physicl, not digital)
when i load paper it feed cockeyed,,,when rollers start it appears to only fee on one side and crinkles paper ..turns sideways and stops feeding....Help !
Nov 24, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Printer heads won't move into view....just makes a grinding noise. All lights are flashing. Thanks!!!!
with it making a "grinding" noise, I first wonder if you have children. if so, then open the lid and/ or look in the paper feed area for plastic tools, band aids, etc. (worked in tech support and once had a gerbil stuck in a printer by it's tail! OUCH!)
if not, then try this procedure that I found else-where on Fix-Ya.
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons, then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Feb 24, 2009 | Epson Stylus 880 InkJet Color Printer
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
X1195 feed problem
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Aug 01, 2008 | Lexmark X1195 All-In-One InkJet Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
HP PSC 2210 All-In-One InkJet Printer Logo
141 people viewed this question
Clive
Clive
Thomas F. Schneider
