Question about Kenwood Sirius KDC-MP225 CD Player
Changing clock time on Kenwood Sirius KDC-MP225 Car Stereo
I found the manual online and it was100% unhelpful. The first step is to "Select Clock Adjustment mode," but it doesn't explain where that is or how to get there. Can anyone help?
  • 3 Answers
SOURCE: my kenwood stereo kdc-135 cr will not display the clock time.
Hold in the button that you change tracks or change radio station with
Posted on May 12, 2009
simplemitch
  • 752 Answers
SOURCE: clock
you have to get into the menu. Here is a link to the manual to help you do it. http://inform2.kenwoodusa.com/manuals/KDC1028.pdf
Posted on Sep 15, 2007
  • 69 Answers
SOURCE: tuner error
Use a multimeter to check for connectivity to the sirius. Where did you mount the antenna? Maybe its a reception problem? Sounds like the head unit is going bad. Try shutting it down, and take the pace plate off, let it reboot and see if it works. Check to see if the Tuner is unplugged.
Posted on Aug 14, 2008
jyackle5
  • 8197 Answers
SOURCE: cant set clock kenwood kdc 2011 s stereo
Here is a manual on how to set the time page 22.
http://inform3.kenwoodusa.com/manuals/KDC3011.pdf
Good Luck
Please Rate FixYa!
Posted on Dec 19, 2008
SOURCE: Don't know how to set clock on kenwood kdc-138 without manual
change the tune mode to standby mode. Then press menu button for few second until clock word is displayed on the screen. Afterward, press the center of the main control button on the right side of the stereo system. The time is now blinking and you can start set the time by pressing upward & downward button for hour and left & right button for the minute
Posted on May 18, 2010
Set the clock on Eclipse CD3414? step by Step
Turn [SEL] button to select CLOCK ADJ.
Press the [SEL] button. The clock adjustment mode is activated. Turn [SEL] button to display the item to be selected for adjustment. Hours, minutes or exact hour will be switched each time the button is turned.
Press the [SEEK /FAST ] button. [SEEK ] button: Turns the time forward. [FAST ] button: Turns the time back. To set the clock to 0 minutes, 0 seconds (an exact hour), press the [SEEK /FAST ] button.
For example: At 3:29: Pressing the [SEEK /FAST ] button returns to 3:00. At 3:30: Pressing the [SEEK /FAST ] button advances to 4:00.
Press the [RTN] button. At this time, other adjustments can also be made in Function Mode. 6 Press the [FUNC] button to exit Function Mode.
Also, you can read the manual here:
http://www.eclipse-web.com/us/download/manual/manual/pdf/CD3414(1-1455A).pdf
Jan 27, 2017 | Cars & Trucks
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
How do I set the clock on a kdc-mp522 CD player
Step 1:
Enter Menu mode
"MENU" is displayed.
Step 2:
Press the [FM] or [AM] button.
Select the "Clock Adjust"/ "CLK ADJ" display.
Step 3:
Press the [Down Search] or [Up Search] button for at least 1 second.
Step 4:
Adjust the hours
Adjust the minutes
Press the [Down Search] or [Up Search] button.
Step 5:
Hope that helps.
Cheers,
Scott
Jan 15, 2013 | Kenwood Sirius KDC-MP522 CD Player
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Step 3:
Enter Clock Adjust mode:
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
Resetting the clock
Follow the instructions on page 20 of this manual.
Nov 13, 2012 | Kenwood Sirius KDC-MP225 CD Player
How to set my clock
In Standby mode
Push the Control knob towards [FM] or [AM].
Select the "CLK ADJ" display.
3 Adjust the hours
Adjust the minutes
Push the Control knob towards Track up or down.
Feb 02, 2011 | Kenwood KDC-MP235 CD Player
Cant adjust the time o the clock
  1. Select Clock Adjustment item during Menu mode (In Standby mode see below for standby mode explained). Select the "Clock Adjust" display.
  2. Enter Clock adjustment mode. Press and hold the control knob for at least one second. The clock will blink.
  3. Adjusting the clock. Push the control knob towards the left or right to select hours or minutes. To adjust each item turn the control knob or push it towards up or down.
  4. Exit clock adjustment mode. Press the (FNC) button.
  • Turn on the power.
  • When the power is ON, select a source.
  • SRC Select mode 1: PRess the (SRC) button and then turn the Control nob or push it toward left or right.
  • To determine the selected source, press the Control knob.
  • SRC Select mode 2: Pressing this button each time switches between sources.
  • Turner ("Turner"), USB or iPOD ("USB" or "iPod"), CD ("Compact Disc"), Auxiliary input ("AUX"), and Standby ("STANDBY")
  • Press at least 1 second to turn off the power
Nov 10, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
I have kenwood kdc mp225 and cant figure out how to turn amp on through radio
there should be a blue/white stripe wire. run this wire to the remote turn on of the amp.
Oct 11, 2010 | Kenwood Sirius KDC-MP225 CD Player
How do I adjust the kpc-mp332 clock? I have the instruction manual, but I am unable to perform this operation per the steps written in the manual. Is there a little know secret on how to do this. How do...
3 Adjust the hours
Adjust the minutes
Push the Control knob to or >>
Try to use the knob to select the clock display, and or by other means. If that doesn't work you can always get back in to the menu. Play with it till you figure it out.
Sep 19, 2010 | Kenwood KDC-MP528 CD Player
How do i set the clock
Select the "Clock ADJ" display.
Press the [4] or [¢] button for at least 1
second.
3 Adjust the hours
Adjust the minutes
Press the [4] or [¢] button.
May 19, 2010 | Kenwood eXcelon KDC-X679 CD Player
Kenwood Sirius KDC-MP225 CD Player Logo
204 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
