My averatec laptop wireless can't connect the internet.
SOURCE: compaq laptop won't connect to internet
on my hp the light is blue when switch is on. go to network and conn. and make sure ur wireless is turn off there. cause if my switch is in the on position and i turn it off hp wireless assistant the light will glow orange eventhough the switch is on . ? Just had an issue simular to this one, hope it helps.
SOURCE: WLAN switch button does not work
Locate your wireless card compartment on your computer. It is probably on the back of it. Your computer manual should tell you where it is. Open the compartment and locate your wlan card. Remove it from your laptop for about 30 seconds, and then reinsert it and make sure that the proper connections to it are firm and secure. Close up the compartment. Turn on your laptop. Your laptop should search and recognize it. If it doesn't, then your wireless card probably quit working on you. If your computer is still under warranty, and if it doesn't recognize it after you have tried this, then you can contact your computer manufacturer and explain to them what happened. They should replace your wireless card at no charge. If you bought the wireless card from some other store, then take it to them and explain to them, and ask for a replacement wireless card.
SOURCE: wireless switch
Try Fn+F11. It worked for my friend who had the same problem on an Averatec n1000.
SOURCE: ASUS PRO50G series laptop, wont connect to my wireless internet
pls tell me when u clik on connect wi fi what error come.
r u able to connect or not let me know please
SOURCE: averatec buddy cant find wireless connections!?
As far as i know the it's a keyboard toggle, hold down Fn and hit the F11 key.
Remember to update the driver once connected.
Regards.
