Cannot insert replacement print cartridges in printer. Gap is too narrow. I have replaced cartridges many times without a problem. This is a H P Photosmart C 4180 All -in-one
  • 300 Answers
If the cartridges are physically larger than the opening, it could possibly be the wrong cartridges. You may want to verify that the model of cartridge is compatible with the printer model.
If you can reply with the printer model, we can tell you which cartridges you need and more specific information on how to insert the cartridge.
Thanks
Posted on Jan 08, 2009
    Genius:
  • 2,920 Answers
Do you have the right cartridge for the machine? could u have accidentally gotten the wrong cartridge?just wondering if that were possible
  • 716 Answers
Please Confirm You Are Using Hp Replacement Cartridge 99,93,95,98 or 100
    President:
  • 2,110 Answers
  1. Place the unit flat on a level surface.
  2. Open the print cartridge door by lowering it until it stops. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Print cartridge door and print carriage Cannot insert replacement print cartridges - c00654617.gif
  3. Pull the pink tab to remove the tape from the print cartridge. Figure 2: Removing the pink tab c00439573.gif CAUTION: Do not touch or remove the ink nozzles or copper-colored contacts, or re-tape the cartridges. Figure 3: Do not touch ink nozzles or copper-colored contactsCannot insert replacement print cartridges - c00439574.gif c00439574.gif
  4. Insert each print cartridge as follows:
    NOTE:
    • Insert the tri-color print cartridge in the slot on the left side, marked with a green label.
    • Insert the black (or photo) print cartridge in the slot on the right side, marked with a black and orange label.
    1. Hold the print cartridge with the HP label facing up.
    2. Push the print cartridge firmly into the corresponding slot until it snaps into place. Cannot insert replacement print cartridges - c00654618.gif4: Inserting the print cartridge c00654618.gif Cannot insert replacement print cartridges - c00654619.gif Figure 5: Print cartridges properly installed c00654619.gif
  5. Close the access door. Figure 6: Access door being closed c00654620.gif
  • 19,396 Answers
That means that you are using the wrong cartridges, go back to seller and get the right ones.
    Genius:
  • 1,550 Answers
Just check whether the cartridge you got is for that particular model and also whether the cartridge is genuine one .
If your problem continues then the print cartridge contacts are dirty and the printer cannot detect a print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Carriage swings from one side to other
Remove the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds before plugging it back in. Once the printer's ready, re-insert the cartridges. Close the cover. It should try to print an alignment page. Let it print the page all the way through without cancelling it. If carrier is not slamming to the sides anymore, problem's resolved. But, when after re-inserting the cartridges and the printer tries to print the alignment and still slamming the carrier to the sides, that sounds more like a mechanical problem and needs to be replaced. If your printer is still within warranty, you can call Lexmark. They might send you a replacement. Good luck!
Apr 06, 2010 | Lexmark X5495 All-in-One &USB...
My printer wont print in color and the cartridge is new
take out the cartridges and clean the contact points on the back of the cartridges.
then without the cartridges we need to perform a rest on the printer.
unplug the power cable and then press and hold down the cancel and color copy button (green one) at the same time, and on the other hand plug the power cable back into the printer, then release both the buttons.
then insert the cartridges into the printer, it will align the cartridges again and then try to print or copy and check.
if still not working then try with different set of cartridges and if still not working the contact point on the printer are bad ..need to replace the unit
Oct 21, 2009 | HP PSC 950 All-In-One InkJet Printer
Hp photosmart 335 - cartridge failure
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP Photosmart 335 InkJet Printer
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Insert C toner cartridge
Have you tried upadtaing the firmware?
Mar 19, 2008 | HP Color LaserJet 4650DTN Printer
Prints without any errors but no ink on the paper.
if you have new print head assembly and cartridges, and waited for flow, and the printer is MECHANICALLY sound (not dropped or G-force damaged), then all that is left is improper cartridge installation. You may not have the cartridges fully inserted/, or maybe they are not PROPERLY inserted. Look for a snap when in place (and no wiggle). I suspect this is your problem, because one symptom you mention, ink accumulation INSIDE the head/cartridge cradle, is VERY rare -unless the cartridge is inserted improperly. The cartridges/head assemblies have VERY good seals to prevent leakage. Unless the o-rings/seals are damaged, leakage outside the seal just does not happen at all, normally.
*New head/cartridge installs can take several hours -sometimes even a day in cold weather, for small iP90-like printers to saturate the heads -and print.
Oct 08, 2007 | Canon PIXMA iP90 Mobile Printer
20 people viewed this question
