Panasonic UF7100 J43 misfed paper error code
I cannot see how to access the paper jam as nothing is visible and there are no levers or panels that can be removed without unscrewing.
    Genius:
  • 2,120 Answers
Did you pull out the toner cartridge and look?
Pull out the paper casstte, above that is a pull down access plate with a green handle.
Posted on Jan 09, 2009
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
I have a Panasonic DP180 with an error message J43
more then likely you need to replace the fuser unit
May 21, 2010 | Panasonic PanaFax UF-8000 Laser Fax
REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I have a Panasonic DP180 with an error message J43 but I cannot find any 'misfed paper'. I have just changed the cartridge (only. Thank you and regards, Lynette
It seems that one of the switches under the toner cart is knocked off.Check and let me know, the update.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 09, 2010 | Panasonic Office Equipment & Supplies
Paper Jam J43
One of the switches under the toner cart is knocked off.
Aug 09, 2009 | Panasonic PanaFax UF-8000 Laser Fax
UF-8000 J43 Jam (Not There)
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Apr 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic DP-1810P Laser - J41 error code
i think the fuser sensor lever on your machine is damaged.
its the lever that you usually see when you open the cover the fuser unit.
Apr 02, 2008 | Panasonic DP-1810P Laser Printer
Panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Sep 01, 2007 | Panasonic DP-1810P Laser Printer
315 people viewed this question
k24674
jasbo
jasbo
