Question about Zebra 105SL Thermal Label Printer
After About 10 tickets a white line will start showing up in the
White lines will appear in the barcode lines after it has printed about 10 tickets.
  • MICKY1974 May 11, 2010
    Hello, are the white lines straight up, or diagonal?
  • 54 Answers
If printing with ribbon, check to see if you have ribbon burnt onto the printhead. If so, lower the temp of the heat on print. Or you can speed up the print speed.
I have seen this happen alot when the ambient temp is low, and the printer tries to make up for the differences in temperature.
Check the hed first..
Posted on Feb 25, 2009
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
A thin white vertical line is appearing in left of my HP w1907 wide screen 19" LCD moniter
I suggest try to calibrate the monitor, while calibrating the monitor and it has the white line it could be a hardware problem that the monitor is bad but if you want to make sure try loading to BIOS and see in BIOS if it has the white line, If so, It really means that its really a hardware problem.
May 08, 2011 | Computers & Internet
Z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
Jun 09, 2010 | Zebra Z4Mplus Label Printer
DARK LINES/SHADES APPEARING ON BACK OF PRINTS
when the print-out shows lines or streaks on the back of the paper when printing single sidedly, this usually means that the fusing unit is dirty or broken. another possible broken part may be the photoconductor unit.
Apr 20, 2010 | Canon iR 2016i Black and White Copier
Gaps in barcode with Zebra S4M
By gaps, do you mean a "void" area ? Over time, the elements on the printhead will wear down and finally they won't transfer heat to the ribbon. This causes a gap or void area. Usually the elements go out one or two at a time. If the area that is worn out is supposed to be printing bars for the barcode, this will cause the scanning problem you are experiencing.
The best way to see if elements are worn out is to design a label that has a thick solid black line across the label or a solid black box. You will see white vertical lines in the areas where elements are worn out. Another method would be to use the widest and longest label you have and print a 'pause" test label. This is done by turning off the printer, pressing and holding on the PAUSE key while turning on the printer. Hold the pause key for 10-15 seconds and when the printer is done with it's power on self test, it will start printing out a test pattern label which includes a nice black area where you can look for the white vertical lines.
Hope that helps !
Mar 30, 2010 | Zebra S4M Thermal Label Printer
Every few lines of print there is a thin white line that shows up in the middle of the line of print, and below the white line the lower portion of the letters look okay but above the white line the upper...
Go throught he maintenance menu and perform a Deep cleaning of the printer nozzles. This will use a lot of ink so use your current cartridge to do this. Once teh cleaning cycle is complete, replace teh cartridge and align the heads with the maintenance menu selction.
Sep 11, 2009 | Dell Photo 964 All-In-One InkJet Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Z4M is printing fine white lines in the barcode
As the label comes out of the printer...it sounds like your printing in picket fence mode (vertical bars). You most likely have 1 or more pixels out on the printhead...try cleaning first...if that fails... you will have to replace the printhead.
Apr 16, 2008 | Zebra Z4M Printer
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
Zebra 105SL Thermal Label Printer Logo
199 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
