Question about Lexmark Office Equipment & Supplies
Brand new Lexmark T644s making "clunking" noises when printing.
Making "clunking" noises when printing.please not: the printer is brand new out of the box.
    Novelist:
  • 140 Answers
This is a pretty general description of a printer making a noise. If it is brand new out of the box, in your user manual it should tell you of some retainers or stops that are put on the printhead and carriage for shipping purposes. Be sure you have read that part and it will give a picture of where they are located and how to get to them to remove them before operation. Good luck and God bless.
If everything is off as it should be, then consider seriously taking it back, it is brand new and it should not do anything but work right.
Posted on Jan 08, 2009
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
Brand new pro901 has 3/4 inch horizontal lines (grey) showing up in multiple areas of printed page. Cleaned print head, problem persists
This sounds like a printhead issue. Please update your printer to fix this problem. The firmware update for the Lexmark Pro901 printer can be downloaded and installed by visiting the Lexmark website at http://bit.ly/p905fw.
If problem continues even after updating your printer, please contact Lexmark technical support for additional assistance.
May 08, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I recently replaced my ink cartridges for my Lexmark X2500 with brand new ones, Lexmark brand, I inserted them and followed instructions and now it still tells me that it can not print that I need new...
  • Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
    Choose "Install a new printer cartridge" under the "Maintenance" tab.
  • Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
  • Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
  • Apr 13, 2011 | Lexmark X2500 All-In-One Printer
    My printer is brand new as are my ink cartriges. My printer prints blue lines over all documents
    Try to manually clean the nozzles on the cartridges. Refer to this article in the Lexmark website on How to Clean the Print Cartridge Nozzles and Contacts Manually. This may improve the print quality on your printer. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
    Feb 21, 2011 | Lexmark X2670 All-In-One Printer
    Printer prints blank page
    Is this a brand new printer? What is the make and model of your printer? Are the ink cartridges brand new? Sometimes when the printer driver becomes corrupted it will print out blank page (page after page) I would reinstall the printer driver that goes to your printer and then restart your computer and try to print a new page.
    http://en.allexperts.com/q/Printer-mechanical-problems-1024/HP-Printer-prints-blank.htm
    http://techrepublic.com.com/5208-6230-0.html?forumID=101&threadID=207297&start=0
    Feb 13, 2010 | Lexmark Office Equipment & Supplies
    Clanking noise when printing from tray 1
    if your getting this noise on every print job the fuser is usually the cause if they have been running on a bit hot they will get flat spots on the pressure roller and it will create a loud kind of clunking sound real common on lexmark lasers. it can also be an envelope setting on some lexmark lasers they have a solonoid for envelope feeding if the envelope inhancment is ingaged in the menu thiscan also cause such a noise
    Feb 23, 2009 | Lexmark E450dn Laser Printer
    My brand new X5340 printer shows there is a paper jam but there isn't one. The one and only sheet it has printed was the test page. Since then, I have been unable to get rid of the "clear paper jam"...
    hi
    follow these steps
    1.checked for and remove any obstructionsfrom paper feed tray.
    2.tilt and shake printer..checked for any rattling noise..checked for any foreign objects inside printer obstructing the paper flow.
    3.Take a sheet of paper ..fold it length wise 3-4 times to make it a thick.insert this into paper feed tray...move it left and right a couple of times..unplug power cable and replug it after 10 seconds...try printing ...if it does not work,,,,contact tech support 1-800-332-4120...ur printer is brand new and under warranty cover,,,they would replace it for u.
    goodluck:))))
    Jan 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Lexmark X1270 Not printing.
    Did you put the right numbers of the cartridges?
    Sep 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
    Lexmark x6170 alignment problems
    Is the ink generic brand or lexmark brand?
    Nov 13, 2007 | Lexmark X6170 All-In-One InkJet Printer
    211 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
