Question about Frigidaire GLWS1233A Top Load Washer
Fridgidaire Washer wont drain
It hums on spin cycle and there is water on the floor! The water is full in the washer also!!!
This appears to be a problem with the pump that removes water from the machine. Impeller of the pump is making noise, water is not pumped out. Pump replacement is necessary. $80.00 for a pump.
Posted on Apr 12, 2009
  • Frigidaire Master
  • 4,654 Answers
If lid lock is bad the tub will not spin properly. Unplug, remove front and look at the lid lock closely. Let me know, Thanks, Sea Breeze
Posted on Mar 23, 2009
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
Oct 17, 2008 | Frigidaire CWS3600AS Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Fridgidaire model fwx223lbs4 will wash, but won't spin fast and the water won't drain
HI thanks for the question it sounds like the pump is either burnt out or jammed with debris thanks the appliance doc
Sep 08, 2008 | Frigidaire CWS3600AS Top Load Washer
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
323 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
