Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Bluetooth is flashing red and blue
The headset is now flashing red and blue and does not seem to connect anymore with my blackberry pearl?
  • carole_brune Jan 08, 2009
    The headset (Discovery Serie) is now flashing red and blue and does not seem to connect anymore with my blackberry pearl?
  • soto14201 May 11, 2010
    what kind of bluetooth?
Sounds like your in pairing mode ... use your phone to search for the device ... when its found the system will ask you for a code ... enter "0000"
Posted on Jan 08, 2009
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
Tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
on Oct 26, 2010 | RIM BlackBerry? Tour 9630 Smartphone
I cant receive anythin om my bluetooth yet i can send,,,my device cant be paired
Hi,the BlackBerry Pearl is a versatile mobile phone. It's primarily a Smartphone that's suitable for business use but it's also equipped with some decent entertainment features. The pearl can also play music files which you can enjoy with the help of a hands free Bluetooth headset. Let me teach you how to pair a Blackberry Pearl Smartphone to a Bluetooth headset.
Things You'll Need:
* Blackberry Pearl Smartphone
* Bluetooth headset
Turn on your Bluetooth headset by pressing and holding the multifunction button.
Check if the LED light is a solid blue. Turn off the headset and repeat the first step if the light is blinking.
Activate the Bluetooth wireless connection on your BlackBerry Pearl by Going into your "Settings" menu
Select the "Options" menu to go to your connectivity settings
Click on the "Bluetooth" option to activate the connection
Choose the "Add Device" option on your BlackBerry Pearl to locate the headset
Wait for a while as your Smartphone locates the Bluetooth headset
Enter 0000 for the password after selecting the headset to complete the Bluetooth pairing process
After that, your Done !!!!you can now send and receive. But after following this instruction and no solution yet, that means there is something wrong with your blue tooth. Corrupted. You will need to reset the phone.
Mar 11, 2011 | RIM BlackBerry Pearl 8120 Cellular Phone
Earpiece won't link to phone anymore
Hi Josh,
there may be a battery or an internal antenna failure on your headset.
You might try re-pairing the devices if you can.
Jan 08, 2010 | Motorola Mobility H700 Wireless Headset
Connect ge bluetooth to blackberry pearl
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Jun 24, 2009 | GE Bluetooth In-ear Headset Wireless...
Need numeric code to pair with blackberry pearl 8100
when pressing the call button to turn on hold it a little longer then usual after the headset has turn on, it will flah red and blue, then simply do a bluetooth scan with your phone, it will detect the headset.
May 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
I cant pair my bluetooth to my blackberry pearl flip phone but my
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 18, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Searching for the headset on the Blackberry
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Connecting bluetooth to blackberry
Hi. You didn't say which Blackberry you have. I'll assume you know who to open "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your Blackberry.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your Blackberry.
Again open "Options"
"Bluetooth"
Open the Bluetooth menu.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Hope that helps!
May 25, 2008 | Plantronics Bluetooth Headset 610 Wireless...
Linking with phone
I struggled with this myself after replacing my RAZR with a blackberry Pearl and losing the manual for my Insten HS120S headset. The key is knowing how to put the headset in "pairing mode". For the HS120S, I finally figured out that you had to hold both the up and down volume buttons until the blue and red LED lights flashed in alternation. Then my blackberry found it on the first try.
Jun 13, 2007 | HP Insten HS120S - Bluetooth Headset Ver...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
4,216 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
