Question about JVC XL-F154BK 5-Disc CD Changer
On my JVC TH-60 disk drawer will not open?
ON THE DISPLAY IT SHOWES A DISK IN 1&3 TRAY BUT IT WILL NOT EJECT THE TRAYS
  • dieman56 Jan 10, 2009
    My problem was a disk in the player and one in the tray .
    Thanks for your help
  • 165 Answers
Hello the problem you have is that the tray is not in time so the security switch dont let to open this try to get ifo how put on time or align the mark on main spindle against the small one hope you undrstood saludos
Posted on Jan 08, 2009
Optical drive tray is open, can't close - disk is stuck inside my notebook
Power it down and if you look very carefully, near the eject button is a hole.Insert a straightened paper clip and the drawer will open. Unless it is a Mac.
Nov 09, 2013 | Computers & Internet
One of the trays on my CD2 will not open. There is a cd still in there. The other tray is working fine. How do I get the tray to eject?
The safe way is to remove the cover. SOMETIMES the problem is a little rubber belt that drives the tray carriage loses traction. To protect the disk, remove the cover and investigate the problem and manually remove the disk.
Jan 01, 2011 | Numark CD Mix2
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Aug 31, 2010 | Sony RCD-W1 2-Disc CD Recorder
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
DVD trays are stuck
Since it is unusable try this. It might help to have so\meone assist if the unit is heavy.
Raise unit and lower the tray end about 45 degrees down, while lightly shaking press the tray open, they might just fall out.
Nov 30, 2007 | JVC TH-C40 System
Disc tray
Something is causing the disc to get stuck inside the DVD player. Open it and inspect. If something is broken, take it to a repair center.
Aug 22, 2007 | JVC TH-A25 System
Disk Tray won't open
is there a tiny pinhole to push in a paper clip to eject the tray?
Jun 03, 2007 | Pioneer DVL-V888 DVD Player
My dvd/cd try does not open when i press the eject button say "locked"
That means your trays are on Child Lock (this is a safety feature to prevent any accidental opening or closing of disc trays by small children when listening to your favorite tracks.)
To solve this, simply switch off your radio to Standby and hold the power button...whilst holding the power button, press open on the tray that is locked....the system will display UNLOCKED on the display of your hi-fi.
That should be it. To lock the tray....repeat the same process on the particular tray u want locked.
May 21, 2007 | JVC DX-T9 System
JVC XL-F154BK 5-Disc CD Changer Logo
379 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
