Question about HP DesignJet 430 InkJet Printer
Carriage belt replacement for HP 430
I need to replace the carriage belt at my HP 430. I already bought the belt from you .Could you please send me instruction (step by step with pictures) how I can do it. May you can lead me to the web where I can see it. Please help.
Alex
  • Anonymous Jan 11, 2009
    replace belt from designjet 430
  • 4 Answers
Http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Posted on Feb 05, 2009
HP Designjet 430 "out of paper" message on computer when it is not out of paper. help please
Check and see if the carriage moves freely from left to right (with power off). If not, make sure the carriage belt is good & the rails it slides on are clean and properly lubricated (light oil).
The paper is detected when the carriage moves over it to determine how wide and how long the sheet is...if the carriage isn't moving, then it says no paper.
It could also be that the line sensor on the carriage is dirty or defective and can't "see" the reflection from the paper. If cleaning the sensor (it is on the RH side of the carriage) doesn't resolve the problem, then the sensor would need replaced, if it is still available that is...
Sep 24, 2013 | HP DesignJet Office Equipment & Supplies
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
I recently replaced the belt in my HP 450C plotter. I hadn't used it in about a year but I put new ink in too. I got one really light test page and now nothing. The print head tries to do the job and there...
it is possible that all the printheads have dried up .try dabbing a wet tissue on the bottom of the printhead,if this does not solve the problem then you need to replace the printheads
Dec 21, 2009 | HP DesignJet 450c InkJet Printer
How can I replace the belt for the ink carriage
Here is an HP Support Forum where a user has posted a detailed procedure for the belt replacement.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=846691
The Service Manual is needed. It's available at:
http://www.hylink.com/PrinterManual.html
Designjet 430, 450, 455C - Service Manual
DesignJet 430, 450C, 455CA - Quick Reference Service Manual
As mentioned, it's a delicate and time consuming operation. I replaced my belt two years ago with little problem. (Be sure to clean the old degraded belt gunk off the drive pully too!)
It's not a job for "Beginners". More like "Intermediate" or "Advanced".
Good Luck!
This is the part I ordered. It was $15
WARNING: THIS IS FOR THE "E-SIZE" MACHINE.
If you have the smaller one, you must research the part number for that.
Carriage belt (E-size) - Long/wide belt attached to the carriage 15.00 0.00 15.00 1 15.00
Oct 21, 2009 | HP DesignJet 450c InkJet Printer
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
How do I replace the carriage belt?
From the service manual:
1. Remove the Left Hand Cover
2. Remove the Right Rear Cover
3. Remove the Right Hand Cover
4. Remove the Tensioner Assembly
5. Pull out Printhead Cleaner Carriage
6. Slide Carriage Assembly to position shown.
7. Lift up the Carriage Cover and remove ALL the Printheads and close the Carriage Cover.
8. Slide the Carriage along the Printer to the position shown.
9. Push in the 2 retaining clips either side of the Printhead Tube Connector.
10. Pull the Printhead Tube Connector towards you.
11. Push the button to release the Printhead Tubes in the Carriage.
12. Release the retaining clip by pulling it away from the holding brackets.
13. Pull the Printhead Tube Connector up between the two Tube Guides.
14. Slide the Carriage to the left side of the Printer.
15. Unclip and remove the Carriage Cover to access the Trailing Cable in the Carriage.
16. Carefully disconnect the Trailing Cable from the connectors in the Carriage PCA. NOTE Remove Trailing Cable
Ferrites if they fall into the Carriage.
17. Remove the Trailing Cables from the Trailing Cable Holder.
TIP Press the Trailing Cables firmly in the center to release.
18. Slide the Trailing Cable Guide out of the Carriage.
19. Slide the Carriage (including the Belt) to the left and out of the Printer.
20. Remove the Belt from the Carriage by releasing it from the retaining clips underneath the Carriage.
As you can see it looks to be a long process. I have the reinstallation instructions as well. If you still want to carry through with this, let me know and I'll send you the service manual....it will be easier than posting the text and the pictures that go along with each step.
Thanks and please take a moment to rate this solution as fixya.
Mar 16, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp designjet 430 cartridge light on
make sure the contacts on the print cartridge and the carriage area where they go are clean. if cleaning the contacts doesn't help then the carriage and/or trailing cable will need replaced.
May 06, 2008 | HP DesignJet 430 InkJet Printer
Hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
Nov 28, 2007 | HP DesignJet 430 InkJet Printer
HP DesignJet 430 InkJet Printer Logo
2,906 people viewed this question
Seeker5211
Seeker5211
