Question about Microsoft Internet Explorer 7
Getting message stating add-on was running when problem occurred
After booting up my computer in the morning and opening Internet Explorer, IE locks up and comes up with the following error message box: ''Internet Explorer has encountered a problem with an add-on and needs to close. The following add-on was running when this problem occurred: Add-Ons name: FSlEEdit.dll Company name: Gaurdware LTD. Description: ISIEEDIT module.
  • Anonymous Mar 18, 2014
    when I open internet explorer it says running with no add-ons yet when I go to turn on in Managing Add-ons it shows they are running
  • 131 Answers
Try going into your control panel & uninstall your Internet explorer, then re-install it. IE7 uninstall can be found in the main add-remove program window, IE6 uninstall can be found under the add-remove windows components part of the add-remove programs. To re-install IE7, though, you need to go to windows update to download IE7 again. This won't be a problem because uninstalling IE7 automaticaly returns you to IE6
Posted on Feb 14, 2009
Keep getting a box popping up talking about script errors. how do we stop that?
If you use Internet Explorer as your Web browser, chances are you have experienced, or will experience, popup script errors. Typically, a dialog box may appear stating "A Runtime Error has occurred. Do you wish to Debug?" or "Internet Explorer Script Error. An error has occurred in the script on line 1. Do you wish to continue running scripts on this page?" These errors can be distracting and interfere with your Web browsing experience. If you would like to stop receiving these error messages, you must modify your IE settings.
Open IE, select "Tools" and ten choose "Internet Options." The Internet Options dialog box will open. Click on the "Advanced" tab, scroll to the "Browsing" section and then select the "Disable Script Debugging" box.
Clear the "Display a notification about every script error" box under the same section if it has been selected. Click "Apply" and then choose "OK" to modify your IE settings. You will receive no more IE script error notifications. Hope this helps.
Jan 01, 2013 | Microsoft Internet Explorer 8
Registry errors
You may have encountered the following message while browsing certain websites:
"Internet Explorer cannot open the Internet site http://<website>.com. Operation aborted."
This really has nothing to do with your browser or your computer. You get this error because of faulty web coding from the webmaster's end.
IE displays this error when it is unable to open a particular element on a web page.
There are many things you can do to troubleshoot this kind of problem.
Upgrade Internet Explorer.
This problem does not occur in Internet Explorer 8. Navigate to Microsoft download Center and click on the "Download" button to upgrade to IE8 or IE9 (see Below).
http://download.cnet.com/windows-internet-explorer-8/3000-2356_4-10910662.html
IE 8
http://www.microsoft.com/windows/internet-explorer/default.aspx
IE 9
Click on "Tools" and select "Internet Options." Hit the "Advanced" tab.
Click to remove the check mark next to "Show friendly HTTP error messages" under "Browsing" sub-headings.
Click on "Apply" and hit "OK." Please note this works mostly for Internet Explorer 6, although there is no harm in trying this on older or newer versions.
Add the specific website that is producing "Operation aborted" error under "Restricted Sites."
Click on the "Security" tab under "Internet Options."
Single-click to highlight "Restricted Sites."
Hit on the "Sites" button and click on "Add."
Type the URL of the website and hit "OK."
This works for Internet Explorer 7, but again, you can try this in earlier versions.
Disable or require prompt for "Active Scripting" when you view the specific website.
Click on the "Security" tab.
Click to highlight 'Restricted Sites" zone.
Navigate down to the sub-heading "Scripting."
Click to select "Disabled" under "Active Scripting."
You may also choose "Prompt" if you want IE to issue a prompt when opening the specific web page or website.
If you are still worried about the registry or need to fix any problems with it
You can run a free registry scan using utilities from http://re7.info
Hope this helps.
Nov 26, 2012 | HP Computers & Internet
I need a fix for internet exployer
Microsoft's Internet Explorer 8 (IE8) browser includes "add-on" applications that can be downloaded and installed from Microsoft, or third-party providers, into Internet Explorer.
Occasionally, add-ons may conflict with other add-ons or software on the computer, causing errors.
These can also occur when IE settings conflict with newly installed add-ons.
Resolve add-on related error conditions quickly in IE8 by resetting Internet Explorer to Microsoft defaults.
Click the "Start" button. Click "Run" or "Search," and type "inetcpl.cpl in the "Run" or "Search" box, and press the "Enter" key.
Select the "Advanced" tab in the "Internet Options" window, then click the "Reset" button.
Click the "Reset" button again to confirm that you wish to reset Internet Explorer to Microsoft defaults.
Select the "Close" button, once the display indicates that the reset process has been completed.
Click the red "X" in the upper-right corner of Internet Explorer to close the browser.
Open Internet Explorer and the errors should be resolved.
also
Experience problems with Internet Explorer 7 right off the bat, and it may be due to installation problems.
Make sure you reboot twice after installing the new browser.
Download any updates for IE7.
Check the Microsoft website for recommended updates if you don't have automatic updates turned on for your computer.
Check your add-ons, those "extras" like ActiveX controls for your browser, if you still experience problems.
After accessing "manage add-ons" through the "Tools" menu in your browser window, disable all add-ons, and try browsing.
If you can successfully browse without errors on the page, then one of your add-ons may be the culprit. Enable add-ons one at a time and try browsing.
Once you find the problem, delete it or update the add-on to work with Internet Explorer 7.
Contact Microsoft if a website denies permission for entering when it shouldn't.
It could be a problem with document. domain property or the protocols of the URLs not matching.
Update and run the most recent version of JavaScript. JavaScript is a scripting language used on many websites.
Adjust security settings in the browser if you still experience page error messages.
Select the "Tools" menu and access "Internet Options." Under the "Security" tab, choose "Custom Level" to pull up the security settings window and review for possible problems.
Hope this helps
Nov 13, 2012 | Microsoft Internet Explorer 8
I'm in a web site and trying to open a PDF File. I receive an error message stating "Internet Explorer Has Stopped Working" Then message comes up that website casued a failure or crash. Internet...
If you have the same operating system, same internet explorer version (from any page click the help button on top of page and select "about internet explorer" to see), and same version of Adobe reader then you might consider running a virus scan. I.E is a target for malware.
Apr 07, 2011 | Computers & Internet
Following rebuild of laptop i have downloaded internet explorer 8. The icon states "internet explorer 8 - without add ons" When opened the information bar states internet explorer operating...
Internet 8 has a compartibility requirement considering the operating systems of the computer, though to an extent the system settings that makes possible adjustments after installation. Once the software has been installed on the computer, any further add on softwares becomes impossible. Newer computers would allow every download especially from the internet onto computer storage with a message of malfunction thereafter. Internet 8 requires operating systems compartibilities to intergrate into the computer achieving additional software intergration. Consider using another internet browser as immediate alternative to resolving internet connectivity issues.
Dec 07, 2010 | Microsoft Internet Explorer 8
I'm doing an on-line computer class and try to attach a file. After I browse and find the file and I can see it in the window and click on attach my computer starts clicking and I get this message Not...
It seems like you have issue with IE add-ons. Please try to open it with IE in safe mode.
Here's how you can disable all addons and run IE 7 or even IE 8 without them:
  • Go to Start > Run
  • Type iexplore -extoff
  • Press Enter
Now, Try to attach the file. If it is solve your problem then:
  • Go to Tools > Manage Add-ons
  • Click on Enable or Disable Add-ons
And than disable few of Add-ons and try to attach file try this until and unless you disable all Add-ons.
Oct 11, 2010 | Microsoft Internet Explorer 7
Unable to start IE8.... and now unable to restore system (vista)
Just use Firefox, Safari, AOL, Opera or other browsers.
Jan 12, 2010 | Microsoft Internet Explorer 8
"Internet Explorer has has stopped working..."
After installing IE8 on vista I kept getting msg Internet Explorer has stopped working - continually looping thru this message.
Solution for me was.
End IE with task manager - needed to do a couple of times.
Then from control panel -> programs -> manage addons I disabled all add ons and then IE started OK. Then by process of elimination stated enabling add on until failed again.
In my case it was the skype addon that was causing IE to fail. Leaving it disabled has allowed IE8 to function.
Apr 25, 2009 | Microsoft Internet Explorer 8
White screen suddenly appears Blank Page Windows
Try these steps first. I assume you are using IE 7. If these steps do not work try reinstalling your IE. Let me know if you need anything else. Good Luck.
Method 1: Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK.
A progress bar is displayed to indicate that the browsing history is being cleared. After this process is complete, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 2.
Method 2: Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
After you do this, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 3.
Note If this method does not resolve the issue, you can restore Internet Explorer 7 to its previous security level.
Method 3: Run Internet Explorer 7 in "No Add-Ons" mode loadTOCNode(2, 'moreinformation'); Internet Explorer 7 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 7. To determine whether the error is caused by an add-on, run Internet Explorer 7 in "No Add-Ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-Ons). Internet Explorer 7 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Method 4.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 7. In this case, use one of the following options.
Option 1: Reset Internet Explorer 7 loadTOCNode(3, 'moreinformation'); Reset Internet Explorer 7 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled. To reset Internet Explorer 7 settings, use Method 4.
Option 2: Use the Manage Add-ons tool to determine which add-on is causing the issue loadTOCNode(3, 'moreinformation'); Use the Manage Add-ons tool in Internet Explorer 7 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  2. Click Tools, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 7.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
Mar 13, 2009 | HP Pavilion dv4000 Notebook
Microsoft Internet Explorer 7 Logo
12,971 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
