Question about Epson DFX-9000 Matrix Printer
We are getting a grinding noise when feeding paper
    Novelist:
  • 125 Answers
Hi Chezicke:
You have gears on the left side of the printer that drive the tractor assembly, they may be worn or loose and not messhing as they should to drive form feed. Remove left side cover to check gears.
pdouglasss
Posted on Jan 09, 2009
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet Pro 8500 Wireless All-In-One InkJet Printer Paper feed will not drop down every time, and is making a grinding noise. Is replacing that piece available?
Hi. You leave a question mark?
I don't understsand what you mean by Papaer feed will not "DROP DOWN"?
I to have the same printer, the paper feeds from the tray (s) from below.
A little more info please?
The grinding in the system trying to feed through the paper.
Just a thought, turn the printer round find the release levers and check the internals for paper jam.
Mar 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
Grinding noise when printing and cuts paper
There may be something stuck in the area of the perforation, like a paper clip, paper debris or some foreign material. I would look in that area with a flashlight and see if there is something in the Paper feed roller area.Something may have come loose if you had a paper jam. Let me know.
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
My printer, makes a grinding noise, when the paper is feeding through when printinig?
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
Mar 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson DFX-9000 Matrix Printer Logo
158 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
