Back to:
Tags:
Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series Vacuum (by 6 users)
posted by sepederson on Jun 01, 2007
My vacuum blows air instead of sucking
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by mpotter, posted on May 21, 2008
vacuum works with attachments except blows are out and has little suction when using the power nozzle. i have a e-series rainbow.
Comment by Guest, posted on Dec 16, 2007
ok, so what's the solution? my rainbow vacuum is blowing air instead of sucking too.
Comment by kvhpkh, posted on Nov 30, 2007
Yes, the motor seems to be spinning backwards - it is spinning counter-clockwise. Is there a solution? Thanks!
My Rainbow is doing the same thing - blowing out air instead of sucking. Any ideas on how to correct this problem?
Comment by niki s, posted on Nov 03, 2007
not sucking. it is pushing air out instead, and a little water
Best Solution
posted on Jun 02, 2007
Helpful (85)
24 seven
Rank:Wiz Wiz
Rating: 82%, 1174 votes
the motor is actually spinning backwards? try to confirm this.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Rainbow E Series Vacuum:
I don't want to Accept this solution
Solution #2
posted on Aug 11, 2008
Not Rated (0)
Bubbabear64
Rank:Wiz Wiz
Rating: 84%, 1190 votes
Sounds like the hose is hooked up to the exhaust instead of the intake. Its tough to get it mixed up when using the power nozzle because the power cord adaptor is located above the intake port.
Thank You!
Solution #3
posted on Jul 31, 2008
Not Rated (0)
candyjal
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Did you try to put the wet hose on the INTAKE instead of the exhaust?
Thank You!
Can you Help with these Vacuums problems?
Once in a while it will make a real faint noise the...
the silver disks or fans how do they go back together
the power nozzel or main unit of the rainbow e series has...
whenever i try to dispense water out of my wet vac the...
was just using it today and turned it off for a moment and...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
