Question about Westinghouse WST1600 Upright Vacuum
If you are going to junk your Westinghouse WT1600 I need a part!
Hi....I hope someone out there can help me. My vacuum works fine but my 13 year old daughter broke a part on it. It's the clear peice under the vacuum...in the manual they call it the " inspection plate." It has to tabs to remove it. My daughter broke one of the tabs off and now when using the vacuum the inspectin plate drags the floor. If anyone out there is going to toss out their vacuum, I'd buy the part and/or pay to have it sent to me. Please contact me if you can help. I'd really appreciate it.
Brian
  • jbriancroker Feb 26, 2009
    Okay....I may be interested...just depends on the cost of shipping naturally. Where are you located. Can you get a shipping cost through UPS....to our zip 94726...Maybe send me your email addy or phone. And thanks.
I have the whole vaccume cleaner and charger in very good condition. You can have it all just pick it up or pay for the shipping . it is FREE . The catch is you have to take the whole machine and charger. This could be a good thing as you may need parts in the future.
Posted on Feb 26, 2009
  • db3105 Feb 27, 2009
    contact me through my email. db3105@hotmail.com. let me know where you are located. and phone if you want to talk.
DYSON DC17 ABOUT 4 YEARS OLD. I HAVE TWO FILTERS THAT I ALTERNATE BECAUSE AFTER 2 HOURS OF VACUUMING I LOSE SUCTION. I HAVE TO WAIT 3 DAYS FOR MY FILTER TO DRY BEFORE I CAN SWITCH THEM AGAIN. THE FIRST TWO...
Hi there! This is John from Jerry's Vacuum Sales in Modesto Ca. Are you using any type of carpet fresh product on your carpet? If so the fine powder is leaking onto the filters and causing them to clog. Discontinue use and over time the problem will correct itself.
I hope this was helpful.
Feb 16, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
sounds like you have the plastic bodied canister. the controll valve inside is bad. I usually just disconnect those to avoid future problems. you may want to take the vacuum to a repair shop though becuase they are a pain to get apart and get back in one piece.
Jul 15, 2009 | Electrolux Vacuums
I have a Kenmore canister vacuum cleaner model 116.23912 that I purchased in 2004. At times the machine works fine, while at other times it will not turn on. I've done a couple of things to try to diagnose...
Since the vacuum is about 13 years old, the on/off switch may have worn out or is wearing out. Go to Sears Online In Store Shopping Appliances Clothing More and you can find parts for your vacuum online. It is a pretty simple replacement part.
Nov 14, 2017 | Vacuums
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
WST1600 upright
Hi , check battery teminals might corroded need clean the post ,unscrew clean and try to charge , if does not full the battery have problem , need to replace.
Jan 21, 2008 | Westinghouse WST1600 Upright Vacuum
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Missing key part for proper function
Get in contact with bissell on thier web site,
They have a spares center,
Nov 18, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Westinghouse WST1600 Upright Vacuum Logo
303 people viewed this question
Top Westinghouse Vacuums Experts
Kevin Getz
Kevin Getz
Tom Chichester
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
