Question about OKI C5150n Led Printer
OKI c5150n I get an error that the printer cannot detect the C drum unit.
I installed new drums for all colors in my printer. Ever since installing these new drum units I continually get an error that the printer cannot detect the Cyan Drum unit. This also causes a paper jam. I have to open the top of the printer clear whatever paper is stuck at the point of the C drum, lift the C drum, open the front of the printer to clear any paper that may have fed and then close everything. Sometimes this clears it up for a few pages to be printed and sometimes I have to open the top again and lift the C drum and put it back in so that the printer can detect that it's there. Is there are way to reset it? Could it be a defective drum unit? I tried contacting the company I purchased it from but never did get a response. Any help is appreciated. Thanks,
  • 186 Answers
It sounds like a defective drum unit. Also make sure you are using genuine oki supplies.
Posted on Jun 26, 2007
OKI C9800 CYAN TONER SENSOR ERROR
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
Jul 30, 2014 | OKI C Office Equipment & Supplies
C530DN 142 error
Image drum up-down movement position detection error. Is the image drum unit removed and installed smoothly? If yes then re-install it If no then Be sure of the connection of the image drum
up-down clutch connector.
- ALSO -
Is the connector of the image drum up-down clutch is connected properly? If yes then Replace the toner sensor board. If no then Connect the image drum updown clutch properly.
Mar 04, 2014 | Oki Electric Industry C530DN Led Printer
Printer COki5150n....
I had the same problem. I came across the 160 error after I moved drums around. My issue started with error code 161. which appears to be the Magenta drum. Moving it to other color locations gave me errors 160, 162, 163. 160, I assume, is the cyan cartridge, then 161 is the magenta, 162 is the yellow, and 163 is the black. In my case, the magenta was very dirty. I pulled it out, used an eraser from a #2 pencil to clean the contacts. Used the shopvac to clean toner power out of printer. Turned it back on and it worked.
Apr 10, 2010 | OKI C5150n Led Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
C5150: All color prints are extremely streaky and
This happened to me. It was caused by a bad "oki compatable" color cartridge. One time it ruined my drum. It was always the yellow color. Decide which cartridge is printing streaky. Remove it, bang it on the inside of a large plastic garbage can. Clean it. Reinstall it . If it still prints streaky throw it befor you ruin the drum. Replace it.
Nov 07, 2009 | OKI C5150n Led Printer
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
May 03, 2009 | OKI C5150n Led Printer
Poor print quality
You need a new black drum.
May 15, 2008 | OKI C5150n Led Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
OKI C5150n Led Printer Logo
207 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
