Question about HP Photosmart M527 Digital Camera
Camera does not stay on
Replace the batteries on the cammera, and when we turn it on it would not stay on.... the screen read lens error 525-12....the lens stayed out.
  • Siddesh Jan 25, 2008
    The camera is not able to start basically. It gives you an impression it is about to start but gives after few blinks.Problem persists even if I put new batteries.
  • 883 Answers
Read manual on how to reset the camera...may be a small pinhole...
Posted on Jun 02, 2007
When turned on screen reads "lens error" and the camera struggles to open the lens. It won't open the screen says error and only way to turn off camera is to pull the battery out.
does the lens seem stuck, does it not extend or retract properly? Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jul 03, 2010 | Nikon Coolpix S210 Digital Camera
I use thais lense on a cannon rebel xti and it takes black pic
Error 99 is one irritant in many Canon SLRs. In general, it means there is some problem with the contacts. So try cleaning the electrical contacts of the body and lens with a pencil eraser.Please take care to hold the camera upside down while doing this so that the residue does not fall inside. Also take out the battery and clean the contacts. Now re-attach everything and try taking the image. Also check if your lens has an aperture ring and aperture lock. If so, lock the aperture ring at the minimum aperture. If these do not solve the problem, try updating the firmware to the latest one.
Dec 12, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
The screen reads "lens error, restart camera. I can not get the lens to retract. I can not get the power to stay on. The cannon screen shows up momentairly - but fades to black and the message appears.
remove the battery, let it sit for at least 2 hours, then put it back. put the batteries back, then gentle push the lens sideways to free its stuck part. if the error still occurs and the lens is not retracting, consult the warranty for the device as the lens assembly gears may be at fault.
regards,
voodoo
Aug 12, 2009 | Canon PowerShot SD1000 Digital Camera
When turning on the camera it shows 'Lens error restart camera'
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 10, 2009 | Canon PowerShot A470 Digital Camera
My camera says "read error" when trying to view pics
You might as well replace the camera, they do not fix these. If you send it in to Fuji you get an exchange camera from Fuji, the cost is fairly high
Apr 14, 2017 | Canon PowerShot A85 Digital Camera
Lens Error!
Hi onikaassing, A very common problem in all the brands "lens error". The remedy is that you have to replace the lens block assembly. Actueally the sled motor start malfunctioning, Contact nikon service centre maybe they have the component level repair facility which can reduce the repair cost. Thanks for using fixya.
Jun 14, 2009 | Nikon Coolpix S210 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Every time i try to turn on my carmera the screen says lens error what does it mean and what should i do about it?
it means your lens is broke mine does it every time i try and turn it on and i have to get a butterknife to open myt camera up to use it its a big hassle what you probly did was had it in a bag or something and the bag was dropped and the cammera lence face got jammed.
Sep 02, 2008 | Cameras
Lens error
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 12, 2008 | Casio Exilim EX-Z750 Digital Camera
HP Photosmart M527 Digital Camera Logo
186 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
teddyboy
Are you a HP Camera Expert? Answer questions, earn points and help others
