Question about Keurig B70 Coffee Maker
Keurig b-70 leaks water from under unit why?
I have a keurig b-70 coffee maker, it started leaking water from under unit, can't find exactly from where?
  • 3 more comments
  • cheevers Jan 13, 2009
    My B70 brewer just started leaking water too. I performed a quick inspection after removing the bottom plate and noticed the water is leaking from inside somewhere at the top of the unit (just before the water is injected into the Kcup). I think it may be a cracked hose or fitting. I need to dismatle the unit further but I will try to find instructions somewhere on the internet first before I break something. Will keep you updated.
  • Jason Morse Jan 15, 2009
    Same here! Yesterday my B70 started leaking as well. I took the bottom plate off and just like cheevers water appears to be leaking from somewhere near the top on the front side.
  • jcjanjax Jan 16, 2009
    I called customer service on my leaking keurig B70 they told me they do not repair, but for $150.oo dollars they would send me a platium newly improved machine, doesn't make the noise , they would inclose some coffee and free shipping. My machine missed the warrenty by a month or so, not that it matters they don't do repairs anyway So what do you do now?
  • Anonymous Feb 27, 2009
    Same problem as above. Lots of water in the dish at the bottom, and also leaking onto the counter and ground.
  • sbecksr May 12, 2009
    mine leaks out the bottom too big mess
  • 4 Answers
SOURCE: Unit leaks out of the bottom
Mine just developed the same problem. Me being an engineer, I decided to take it apart and found the problem. There is an aluminum tube shaped like a "C" with a heating element inside of it. Water flows through this metal tube, is heated, and then pushed via steam pressure. There is a metal brace that holds this "C" piece securely to the bottom of the machine. This brace is sharp and overtightened, which caused a small hole to form in the metal, causing the leak (in my machine of course). I am currently researching how to patch aluminum so I can hopefully fix it.
Posted on Jan 06, 2008
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
Posted on Aug 17, 2008
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: senseo coffee maker
http://www.eserviceinfo.com/downloadsm/19109/Philips_Senseo%20HD7810/10.html
OK above is a service manual, this is what the techs use to fix, it. Use the exploded diagram,and troubleshooting guide, and you will no doubt sort it very quickly.
http://www.devicemanuals.com/guide/Home%20Appliance/Philips/Philips-SENSEO-Coffee-Maker-HD7810-75-54-User's-TXpBNE1qTT.html
Download the user manual above.
Posted on Apr 03, 2010
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
How do I fix a leaking Keurig coffee maker
Keurig has a good warranty program. I would return it and get a new one.
Sep 28, 2015 | Keurig Platinum B70 Coffee Maker
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
Keurig Leaks Water Before Brewing
If it is in warranty, this unit needs factory services. Unfortunately the cheap labor and rapid production rates are more important to the company than Quality.
Feb 16, 2014 | Keurig B60 Coffee Maker
Keurig is leaking out the back along bottom
Seal is damaged and needs replacement. Factory will di free under warranty.
Jan 31, 2013 | Keurig Elite B40 Coffee Maker
Keurig special edition leaking water underneath
Reset and Descale with mix of soulutions Page 18 Manual.
May 15, 2012 | Keurig Special Edition B60 Coffee Maker
Water leaking under maker
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Sep 06, 2011 | Keurig Platinum B70 Coffee Maker
My unit is leaking water from the inside of unit
heatman101
Aug 19, 2011 | Keurig Elite B40 Coffee Maker
The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Mar 14, 2009 | Keurig B70 Coffee Maker
Keurig B70 Coffee Maker Logo
2,187 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
