Question about ViewSonic VG700b 17" LCD Monitor
No sound from speakers in VLCDS23719-1W
Could you tell me whether I can enable the sound from the speakers on my LCD monitor?
  • Roberta Smith
    Roberta Smith May 11, 2010
    do you have them plugged in with a speaker cord ?
Yes, is the speaker wire connected to your pc?
Posted on Nov 08, 2009
How do I turn on the Acer AL1717 speakers?
the internal speakers, RTM it tells you how.
you plug them in to the PC, audio part conn.
then unmute the audio.
then up the volume.
also RTM the monitor OSD may have speaker enable , selection.
that is it.
Sep 26, 2013 | Acer 17" AL1717 Flat Panel Color LCD...
Audio is not supported
Which is it computer audio or monitor audio ? and which computer and operating system ?
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Enable Monitor Speakers
Most Windows operating systems are not set up by default to run sound through a monitor's speakers. Instead, the sound device needs to be manually set to "Monitor Speakers" in the Sound section of the control panel.
Open the "Start" menu and select "Control Panel."
Double-click the "Sound" icon in the control panel to bring up the Sound dialog box.
You may need to select "Hardware and Sound" prior to this, depending on which control panel view you are using.
Click the "Playback" tab, then right-click in the Devices window and select "Show Disabled Devices."
Click on your monitor speakers and click the "Properties" button.
Click the "Device Usage" drop-down menu and select "Use This Device (Enable)." This will enable your monitor speakers.
Aug 04, 2013 | Computers & Internet
Hi why is there no sound from my speakers
In Control panel, check you have the sound enabled by testing one of the windows sound schemes, even if you can't hear anything you will see it is enabled.
Check the volume icon on your desktop taskbar is not in mute mode
Finally, check the wire from the monitor speakers is plugged into the correct port in your sound card / chip. (Usually green)
Dec 28, 2010 | Philips 190B6CB/27 19" LCD
No volume from speakers
open the monitor and connect the connector properly fit then look whether the wires are disconnected or not clear it problem will be solved
Jun 15, 2010 | HP Vs17 17" LCD Flat Panel Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
Not getting any sound from my computer
1. Check whether your speakers are ON!.
2. Sound settings are Enabled and OK!
3. Speaker's wire is in proper jack!
4. Reinstall the sound driver! (last option)
tell me if it helps...tc! :)
Jan 02, 2010 | Computers & Internet
Can I hook up external speakers when my monitor already has speakers? If so can they operate together, or do I have to disable the moniter speakers?
Yes,You will need a spliter make sure its stereo,plug the splitter in at the source and then plug the monitor in one end and the speakers in the other.
Good luck
Sep 07, 2009 | Computers & Internet
No sound on computer
check your sound cables speaker power button and speaker icon on computer is it enabled some dell pc have sound option in biose which needs to be enabled
Jul 22, 2009 | ViewSonic VA721 17" LCD Monitor
No sound from monitor speakers
you have to enable the onboard sound card as a primary sound of your computer
Jul 11, 2009 | X2Gen MG19MY 19" LCD Monitor
Monitor audio hook-up
You should need a mini jack audio cable. One end plugs into the speaker port of your sound card in the back of the computer (usually marked green). The other end should plug into the audio input of the monitor.
Oct 06, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
ViewSonic VG700b 17" LCD Monitor Logo
161 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
