Question about Mitsubishi VS-6043 60" Rear Projection Television
11-year old Mitsubishi VS-6043 picture flickers and bends
As described, the picture flickers and bends for quite a while, then calms down for hours, even days....and starts back up again....sometimes, if we let if "rest" it seems to get better, but now it is quite bad....Any thoughts? Worth repairing or buy new?
Thanks, Skarecrow
    New Friend:
    Problem Solver:
  • 6 Answers
Does it work normally with EXT inputs? If the answer is yes you probably have a tuner doing the same thing as mine with the video signal, namely clipping the sync off of it by mistake. If the deflection was doing this the power supply would most likely shut down. The tuner uses a chip with a black noise clipper of all things, just what you need to remove the sync accidentally, I have a post here looking for an answer. I put a scope on mine and it's weird, video and chroma are OK, just nearly no sync pulses so naturally the TV goes nuts.
Posted on Feb 18, 2015
  • 108 Answers
Check for cold solder joints on the yoke connector located behind the speaker grill and mounted on the crts. You may also want to check for cold solder on the vertical output i.c.
Posted on Jan 08, 2009
Monoscope signal how to get it Mitsubishi VS-6043 rear tring to adjust the picture its all warped looking got tv out of ditch tring to make it work
does the convergence align or move? how is the picture distorted? if the picture aligns but is just warped, use a jig or some string to have some straight lines to reference for your geometry and convergence. the monoscope signal is hard to find and mits had it on a vhs tape back in the day. it really just helped you get the horizontal and vertical size and get a round circle to fix the warp.. just try to make all the grid points about the same distance apart and make it an even grid.
May 26, 2010 | Mitsubishi VS-6043 60" Rear Projection...
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
No problem==somebody gave me mitsubishi-vs-6043 tv and i need to
When new that unit sold for around $2000 and $3000. But that is an older unit and you'd be lucky to get $500 for it now. It was manufactured in 1996 making it 13 years old.
Dec 28, 2008 | Mitsubishi VS-50607 50" Rear Projection...
No picture or sound,clicking in back and speakers thump to clicking noise
Tubes are messed up, to fix is REALLY expensive, trash it or part out what can still be used.
May 21, 2008 | Mitsubishi VS-6043 60" Rear Projection...
6043 6061 parts interchange
Well, you can use most of the parts, except that the shape of the boards are different, so you cant exchange the entire board as such.
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
60'' 11 year old Mitsubishi Projection TV
HELLO THERE WE ARE HAVING THE EXACT SAME PROBLEM. TURNS OUT THAT IT IS THE RELAY SWITCH mY TV IS ALSO 11 YEARS OLD. HAD THE SAME PROBLEM 4 YEARS AGO
Jan 17, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
