Question about Lands Phones
Number Not Provided
I'm not sure if it's my panasonic phone that blocks my phone number from showing up on folks' call ID. It is a panasonic ks-tga931s
    Scholar:
  • 47 Answers
Usually not unless you programmed all of your speed dials with a *67 first. Usually this is set up by you the end user, with the telephone company, having a private/restricted number, or by adding call blocking to your line. If you dial *82 then the phone number of somebody that you have this problem with, the call should go thru. You can have this feature removed by the phone company, however no matter who you call, stores, resturants etc... will have your number for telemarketing purposes.
Hope this helps.
Posted on Jan 09, 2009
Panasonic dect 6.0 plus name and number of incoming calls aren't showing on phones. How can this be fixed?
Do name/number display on any other phones on that line?
If that is your only phone, try borrowing another with working call display from a friend or neighbor. If another phone doesn't display caller info, call your phone company - most charge extra to provide caller number ( and in some cases, another extra to add the name). Even if the features are included in your rate, it's possible they weren't turned on correctly.
Your Panasonic may also have a setting to show name or number - depending on the display size, you may have to pick one or the other.
Finally, some phones do not support exactly the same caller ID info that the phone company sends - I have seen some which displayed number instead of names and no name, just because the two pieces of equipment did not agree on the standard. Try your Panasonic on someone else's line with working Caller ID.
Oct 12, 2017 | Panasonic Lands Phones
Calling number doesn't announce or show on phone
most phone companies you have to pay extra for caller ID
Oct 12, 2017 | Lands Phones
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
Aug 25, 2014 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
My phone number is blocked, how do i unblock? when calling service that does not except blocked numbers?
go into your menu and go into settings. look for phone settings. you should have at least two options. show my number and hide my number. select show my number and then save. this will allow your phone number to show on caller id
May 12, 2011 | Cell Phones
My caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Dec 04, 2009 | Panasonic KX-T7731 Corded Phone
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Lands Phones Logo
102 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
