No problem at all. As long as the phone recognizes the memory card, you can transfer the pics from it. What you do is - connect the phone to the PC as a Mass Storage Device through a data cable using the USB port. It will appear in My Computer as an additional drive which can be used as any other drive in the HDD. Copy, paste, delete, whatever.
However, remember that after the file transfer you must first stop using the card from an icon in the system tray and only when it tell you that it is safe to remove the card, then only detach it from the PC. Else there are chances of you card getting damaged.
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
This is because your Touch Pro is not a Mass Storage device. You have to actually take out the memory card and put the memory card into the Memory Card Adapter and place the adapter into your computer in the memory card slot. You then have to label folders for MUSIC, VIDEO, IMAGES, and DOCUMENTS and then place the files in the corresponding folders. It will make that noise because a USB device is being connected. This device can be used as a modem which is why your computer recognizes it.
