Question about Hampton Bay 24002 Ceiling Fan
40 watt just not bright enough?
Is is okay to use 60 watt, and why in the world would your fans not require bulbs light enough to see in a room?
Don't make sense to me.
I may have to pay electrician to take all these down just to replace with light kit that can actually give us light to write by. 40 watt just cast shadows, very dim.
  • 37 Answers
60 watts could be fine and you may never have a problem, but it says 40 watts for a reason. So you don't burn your house down. See "To reduce the risk of fire....". The better option here would be to buy 23watt compact fluorescent light bulbs. They give off less heat than a 40 watt incandescent and the same light output of a 100watt incandescent. I'm guessing that you don't currently have the light on a dimmer, but if you wanted to, make sure you get cfl's that are made to be used on a dimmer.
Posted on Jan 24, 2009
60 watt should be fine
Posted on Jan 08, 2009
What is the maximum wattage bulb that you can put in the Langston 60" ceiling fan light kit? It comes with 2 - 13 watt CFL bulbs. They are not bright enough, so we would like to make it brighter.
Get new LED lamps with low wattage and high brightness values. Additionally, the LED bulbs last a long time and use far less electrical energy than standard bulbs.
Jan 16, 2018 | Dryers
Odd problem with ceiling fan and LED
This is a common issue with LED bulbs in the application that you have it installed in, When you changed the socket it reset the unit. Most of those wont ever see an LED because the LED wont draw enough current. Then control box depends on a current draw in order to stay on. LEED bulbs don't have enough current draw.
Oct 12, 2017 | Dryers
Can I use 60 watt bulbs to get th brightness I need for hunter model 53155
Only use what's recommended in the manual. Wattage should be on socket also.
Aug 12, 2014 | Dryers
Hunter ceiling fan light turns on but goes out until it cools then comes back on by itself
The globe getting too hot is common with discharge lights but have standard lights. What type of circuit protection do you have as normal overload trip the breaker. I would suggest experimenting with one globe in to see if the problem persists. If it stays on you have to go down to 25w globes - which would still be a touch high at 75w but better than 120w. This could be too dark for you though so an additional wiring solution might be needed
Mar 07, 2013 | Dryers
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 | Dryers
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
Hampton Bay 24002 Ceiling Fan Logo
952 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
