Question about Kenwood KR-V5580
Volume control for kenwood krv5580
Ive got a amp the kenwood v5580 and the volume controlisnt working all im after is a new one and where to sorce one from can you help pls
I was able to get the volume control to work, but how do you get an amplifiter to hook up to it?
Posted on Apr 20, 2009
Kenwood kr 5050 volume stuck on high cant change
These days the circuit of the volume control is controlled by an IC in modern amps. These can go faulty preventing adjustment of the sound by the volume control. The only cure is to find the IC and replace it. You can start in the area where the volume control is located. If it's not mounted direct on the PC board, follow the connections to the board. Hopefully the board might have writing on it to indicate the area where the faulty IC is.
Aug 04, 2015 | Kenwood Audio Players & Recorders
VOLUME CONTOL
Reinstall drivers for sound. then the volume control(mixer) will be put in the tray.
Mar 14, 2012 | Dell Latitude C610 PIII 1.0Ghz/ 128MB/ 16-...
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
Dear sir,my surround amp rear speakers are not working.model is kr-v5580.other functions are OK..Pl's help
1st try a test tone to the rear speakers. If you can not get a test tone check the connections again.. once you get a test tone, use the "mode" button on your remote to cycle through the surround modes and make sure you are in a surround mode rather than a stereo mode.
Sep 29, 2010 | Kenwood KR-V5580
My TV has audio (left & right) & video jacks (red,white &yellow) can I connect my Kenwood KR-V5580 to it for stereo sound If so what do I connect it to video 1 or 2, phone,etc
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Apr 29, 2010 | Kenwood KR-V5580
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
Nov 15, 2008 | JVC RX-E100 5-Channel Amplifier
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Oct 05, 2007 | Car Audio & Video
Kenwood KR-V5580 Logo
311 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
