Question about Clarion VRX755VD Car DVD Player
FACEPLATE ATTACHMENT PROBLEM
THE LEFT SIDEOF MY FACEPLATE WILL NT REMAIN ATTACHED AND SWINGS OFF WHILE IN USE SHUTTING THE SYSTEM DOWN. IS IT LIKELY THE FACEPLATE OR SOME OTHER CONNECTOR PART THAT NEEDS FIXING. cLARION HAS NO FACEPLATES IN STOCK IN THE FORESEEABLE FUTURE
Its usually not the faceplate but the mechanism that holds it down. if this is a vrx755vd i would either be interested in buying it from you as-is or i could sell you the mechanism you need for $75.. You could also send it to me and i could repair it for a total of $200.... email me!!! mikeage2@aol.com ampman out!!
Posted on Jun 20, 2007
El1850g-42w shuts down for no reason
Does it shut down, or shut off?
Shutting off can be a heat issue where it gets so hot it shuts off to protect itself. Check the processor fan to make sure it is spinning, clean out all the dust in the system. BE CAREFUL TO REMAIN GROUNDED SO YOU DON'T SHOCK THE COMPUTER WITH STATIC ELECTRICITY!
Shutting down could be a virus, an installation program in a loop, and whole number of issues that would be too long to go into here. If this is the case, call a professional.
Dec 16, 2013 | eMachines EL1850G-42W Intel Celeron E3400...
When I turn on my cp it says "Windows could not
Open the left panel of the computer case, try to unplug and clean the contacts of the wires connecting to the hard disk, both power and IDE. If this does'nt solve the problem, you must re install your operating system . Sorry but it always happen when you either accidentally turnoff your computer without doing the proper procedure, by means of shutting it down properly.. Have a nice day !!!
Aug 17, 2011 | Coby 10" NBPC1023 Netbook PC
2003 Oldsmobile Alero dash board is out and car wont start
The ignition switch is bad,the passlock security system is shutting down the injectors so it can'nt be started.Computer can not read the code on the key.
Apr 25, 2011 | Oldsmobile Alero Cars & Trucks
I receive email with attachment. But anti virus from yahoo mail detect a virus in that attachment. So i can't download that attachment. I still want to download that attachment. What the solution? thank...
If you manage to download this file you will most certainly infect you PC with a Trojan Horse, Worm, or Spyware, these virusus remain on your computer copying valuable information and remembering keystrokes and send them back to the creator or host. It is therefore important that you forget about this attachment and somehow find it from a more reliable source. If it is from someone you know I have written a tip on some really good Free AntiVirus programs, (it can be found here: http://www.fixya.com/support/r6790239-virus_infection_best_free_anti_virus), that you can download and install, then run a full scan on the PC with the file. Once the PC is clean the files that are infected can be healed. The file can then be re-attached and sent virus free.
Nov 15, 2010 | Yahoo Mail
My xbox wont turn on
Your console should turn on when the eject button is pressed. Press the eject button on the front of your console.
If the console turns on when you press the eject button but not when you press the power button, the console faceplate might not be attached properly. To make sure that the faceplate is attached correctly, you should remove it and reattach it.
  • Position your console horizontally, as you would position a DVD player.
  • Unplug the power cord and any other cables connected to the back of your console.
  • While holding your console firmly, curl your fingers inside the oval USB door on the front of the console.
  • Push the faceplate away from the console with your thumb until the faceplate comes off.
Note You will need to use some force to remove the faceplate.
Once the faceplate is removed, look at the tabs on the back. If any of the tabs shown in red in the illustration below are broken, order a replacement faceplate by contacting Xbox Support.
If none of the tabs are broken, re-attach your faceplate by pressing it firmly until it clicks into place.Try to turn on your console again. If removing and reattaching the faceplate did not solve the problem contact the xbox support.
Thank you!
Jul 31, 2010 | Microsoft Xbox 360 Console
After shutting down display buttons remain lit
are you shutting down using the power button? It may be programmed to do another action ( standby or hibernate ).
start menu > control panel > performance/maintenance > power options > advanced tab .
Oct 14, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Gas meter is fluctuating from to full -meter shows more than 1/4 and vehicle is shutting down/stalling fro gas.
for the car pulling to the left make sure ur alingment is withing spec, then u check caliper and brake hose.make sure hose is not kinking or caliper piston not getting stuck. as for the fuel check ur nidle on dash if fine ur hanger is bad. i thing urs is a fuel pump ***,(pump and hanger)
Sep 11, 2008 | 2000 Chevrolet Astro
HELP ME JVC GEEKS! Spring problem keeping faceplate on....
this might seem ridiculous but try heating up a needle that is no more then half the size of the nub and sticking it in the dead centre of the nub, once its cooled down cut off however much of the needle you have to and see if that works, an even more ghetto way of fixing it would be shoving a small straw over the nub to extend it.
good luck
Jul 26, 2008 | JVC KD-G720 CD Player
Computer says nt authoritysystem
Hi, it sound to me like you have a heat problem.
Check your heatsink fan on the processor and also clean out all dust from the haetsink and motherboard.
Regards mistyman
Oct 10, 2007 | Intel Motherboard
Clarion VRX755VD Car DVD Player Logo
257 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
