Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
User profile problem/Mb
I went to My Computer and opened up the Properties Window to check why I was recieving MB memory errors when I go to install my printer. It showed me 224MB. But when I purchased this Computer I was suppose to have had 854 MB and 588 KB. I am trying to find out how to correct the problem. Clicked on the Advanced tab in My Computers Properties Window and went to Users Profile and seen my accounts. What is wrong? Can You Help Me?
  • opheliadavis Jan 08, 2009
    Where is my FixYa?
  • 36 Answers
Ok, 224 MB ram sounds like 256Mb with 32 being used for Video Ram. 854 MB would be a non standard amaount of ram., in other words, it is not divisible by 128. If you have more than one ram stick in the machine, then it is likely that one of them has gone bad an dwill need to be replaced.
Posted on Jan 08, 2009
Slow loading,game cutting off
Try adding more RAM
Adding more ram will boot applications / games quicker
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask or get working pairs in a ram upgrade some ram modules wont work together even if they are of the same brand and type ie: DDR ,DDR 3
Checking Amount of RAM
Click on "My Computer" and select "Properties" using right-click in the Explorer window.
This will open "Systems Properties."
Click on the "General" tab.
Here you can view the physical memory installed on your computer.
The amount indicated is the total RAM installed on your computer.
RAM is usually 32 MB, 64 MB or 128 MB in older PC versions.
Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
Check the usage.
To know the currently used RAM (based on programs you are running), open the taskbar or press "Ctrl + Alt + Del" to open a pop-up window. Click on "Task Manager."
Click the "Performance" tab.
You can view the amount of memory currently used by each program running on your PC.
Mar 18, 2014 | Computers & Internet
Vram is 256 mb but dedicated is 64 mb and shared is 192mb . how do i change it.. no option in bios also. Sony vgn n220e
You should not change this. Laptops have small video chips and often depend on "shared" memory to achieve good performance without overheating. Basically, the video processor borrows some of your installed RAM memory. Also, your laptop may have been supplied to you with less total RAM memory than the maximum and you can add more memory. In Windows, click on Start then right-click on Computer and select Properties. In the Properties window you can read how much total memory is installed. 2GB (2048MB) is a desrirable amount for Windows XP. Windows Vista and Windows 7 can benefit by having total 4GB of RAM memory. Check your Sony user manual for instructions on adding more memory. Basically, you turn off the laptop, remove the battery pack and unscrew a small cover on the bottom of the laptop to access the memory slots. Usually, there are 2 slots here. Ideally, you should install a matched pair of memory modules (a "kit") for peak performance. However, quantity of memory is more important than having matched modules, so if one slot is occupied and the other slot is empty you may simply buy one more module and install it in the empty slot.
Aug 13, 2013 | Sony VAIO VGN-N220E/W Notebook
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
Major memory reference error
The memory could not be read message indicates to me that you may be experiencing a problem with your RAM. Test it doing this Test your RAM with Windows Memory Diagnostic tool
Feb 27, 2017 | Fujitsu Siemens Amilo Pro V3515 Laptop...
Message says that there is insuffient memory when trying to install or run Windoes 98Se on machine with 2MB Ram
FYI,
Minimum hardware requirements for Windows 98:
1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended).
2. 16 megabytes (MB) of memory (24 MB recommended).
3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install.
4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install.
5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install.
6. One 3.5-inch high-density floppy disk drive.
7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
Hope it helps.
Oct 30, 2010 | Microsoft Windows 98 for PC
Graphics
1) enter bios
2)make changes in shared graphics to 128 mb
3) increase the size of page sys file allocate more ram to page.sys file by going into rt click my computer/properties/ performance/
4 u can change your windows system to 64 bit.
Sep 19, 2009 | Intel D945GCCR Motherboard
Phone memory problem in nokia 5130
Hi, empty the phone memory by transfering the data stored in the recieved folder. This folder saves the data recieved thru bluetooth.
Jul 27, 2009 | Nokia 5130 Cellular Phone
I installed the CD for Jumpstart Spanish 1st-3rd grade- 2nd edition but at the end of installation, I got an error message about needing at least 3mb of memory and then it ends installation and the program...
To fix, try this
Right-click on My Computer icon, and select Properties.
Click on the Advanced tab,
then select the Settings button within the Performance section.
In the Performance Options window, click on the Advanced tab, and then select the Change button in the Virtual Memory section.
Click the Custom size button...
Change the Initial size (MB) setting to 4000
Change the Maximum size (MB) setting to 4000
Select SET to accept the change, which will close the Virtual Memory window. Select OK to close the Performance Options window. And select OK to exit the System Properties window.
please rate my solution
have a nice day.
Jul 07, 2009 | Jump Start JumpStart Spanish...
Cannot install 6940 driver
this is straight from hp
64 MB RAM for basic software installation (256 MB RAM for full software installation), 200 MB available hard disk space for basic software installation (450 MB for full software installation)
unless you get another 256mb memory it would be best for you to do basic installation.
Mark
Apr 21, 2009 | HP Deskjet 6940 InkJet Printer
I/O device error
Make sure you have media player 11
then format the player and try again
Jan 28, 2008 | SanDisk Sansa c140 MP3 Player
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
