Question about Advueu Technology ADV17C (Beige) 17 in. Flat Panel LCD Monitor
Blank Monitor I moved my computer to a new location and when I hooked it up, I could faintly see the screen. How do I adjust the brightness on the screen?
  • 883 Answers
Is there a button switch on front panel to enter the on-screen menu settings? if so, find the proper menu for brightness.
Posted on Jun 02, 2007
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Blank Monitor laptop screen
You may have a blown inverter, this is a small component found at the bottom of the screen. It is a simple fix.
You can search for one on eBay, simply search for "<your model> inverter".
Should be around £10.00
Once you receive it, pry of the front of your screen bezel with a small sharp screwdriver and locate the inverter at the bottom of the screen. Replace it with the new one.
This should solve your problem.
The fact that you see information when you boot means that the screen is fine. It is more than likley the inverter.
Mike
Aug 24, 2009 | Acer Aspire 5720-6661 Notebook PC
Screen is blank but can still see cursor
HI, ON THE UPPER OF YOUR KEYBOARD THERE IS A KEY THAT THE SIGN v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} 280 7772400 10058400 259 261 257 275 262 278 1 01[;?IN3)?T&<$N9H&7JY+0 5 1 0 281 False 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 277 134217728 8 Empty 16711680 52479 26367 13421772 16737792 13382502 16777215 Bluebird 22860000 22860000 (`@````````` 266 263 5 110185200 110185200 True True (``````````` (``````````` 0 419100 428625 clip_image001.gif moz-screenshot.pngOR SYMBOL LIKE YOU A SUN. PRESS THAT KEY THAT WILL ADJUST THE MONITOR BRIGHTNESS.
Aug 13, 2009 | Sony VAIO Notebook
Faint green discoloured screen then screen is blank
Sounds like one of your florescent tubes have died. THe power circuit is trying to start it but fails then shuts down
Nov 10, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
My computer monitor has somehow turned its brightness all the way down, possibly due to me choosing a new screensaver which was already installed on my computer. Sadly, my monitor, an Emprex LM-1704...
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Sep 09, 2008 | Computers & Internet
Tha display screen is dark, shows very faintly.
Can you be more specific ?
The first step is to isolate the system at fault:
1) Monitor hardware ?
Test it on another PC or
Try a different monitor on the same PC
Check monitor adjustments.
Check the video cable, try another one.
2) What kind of a monitor is it?
CRT (like and old TV) or an LCD flat screen
3) Video card problem, possible but not as likely
4) Video driver or operating software settings issue
wrong video mode, video settings the monitor can't handle,
incorrect device driver
lots of possibilities here.
MJS
Apr 18, 2008 | Computers & Internet
Advueu Technology ADV17C (Beige) 17 in. Flat Panel LCD Monitor Logo
61 people viewed this question
Top Advueu Technology Computers & Internet Experts
Alun Cox
k24674
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
