Question about Kicker (ZX750.1) Car Audio Amplifier
No output My amplifier is hooked up correctly and the green power light is on. I don't get any bass out of the subwoofer unless I turn the gains all the way up. It was working fine for about 2 months. I have 13.5vDC at the positive and negative terminals. I tested my subwoofer on another amplifier and it works fine. What could be the problem?
  • 1 more comment
  • mellow_k_79 Jan 19, 2009
    pioneer dvd
  • TDWPgtp May 11, 2010
    have u tried a different set of RCAs or made sure that they are connected at your head unit?
    what kind of radio or head unit do u have
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
The output input cables try that first
Posted on Oct 16, 2013
3 Suggested Answers
  • 631 Answers
SOURCE: No power output
Set the meter to AC volts and measure the AC voltage on the RCA cables where they plug into the amplifier. The black meter leat will go on the shield ground of the RCA cable. The red lead on the center conductor. You may have to turn the volume up to get a reading on the meter. At high volume, you should read at least one volt but the actual voltage will vary due to the audio signal. If you get no voltage on the RCAs, measure the AC voltage on the input to the LOC. Let me know what you find.
Posted on Oct 05, 2007
Bennytechkid
  • 99 Answers
SOURCE: i have a kicker 750.1 amplifier. I was playing it
I would say that your subwoofer Or speaker leads have shorted out...when the bass hits as you say it drives the amp hard but if it is trying to dump power onto a shorted speaker or speaker wires it will blow the output power transistors not to mention other vital components of the power amp...i suggest you test your speaker leads with a Multimeter on the ohm setting before connecting a repaires or another amp.. to make sure there is no short on the leads and that the resistance is around 4 ohms or so depending on how you have your drivers wired...but anything lower than 2 ohms will cook an amp! you can normally pick up a meter from anywhere for around $10..
Posted on Jan 14, 2010
I have a pioneer dxt-x4869bt sterio do I need a certain hook up subwoofers
Unless your Pioneer has a dedicated subwoofer output or output for bass speakers the signal for subwoofers will need to be generated by either a passive or an active crossover from the regular speaker outputs and then the resulting output will probably need boosting by an additional amplifier if a passive subwoofer is to be used. An active subwoofer might not require the additional amplification.
Feb 14, 2016 | Pioneer Car Audio & Video
Im trying to hook up a paradigm pdr-12 to my tv and xbox 360 and need an idea of how to do this the right way so it only plays the bass and nothing else
Hello there this subwoofer has a built in crossover variable from 50hz to 150hz which means that any signal you feed it the sub it will ignore anything but bass anyway.
As for the connection it is made quite difficult if you don't already have an amplifier powering your other speakers, usually home cinema amplifiers have a low level pre out for subwoofers, for which you would just need a phono to phono cable.
However if it doesn't and you have any type of amplifier with at least 2 separate left and right speakers you can connect the wires from these into the subwoofer and it will output the bass from these 2 channels.
Another option is to use a mono to stereo (2 to 1) phono cable where the 2 connectors at one end connect to a tape or record output on your amplifier and the single phono at the other connects to the subwoofer, the same would go if you have a red & white phono (RCA) output on your TV you could also use this to power the sub, in the worst case scenario you could use a single to single phono or rca cable to connect one of the output channels (left or right) on your TV to the subwoofer however this would mean that the subwoofer would only output bass from either the left or right channel.
Hope this helps
Kind Regards
Ant
Aug 26, 2011 | Audio Players & Recorders
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
NO BASS!!
1) Check the Subwoofer for continuity - At the subwoofer, one at a time, test the terminals for Continuity using your Digital Multi-Meter; if your DMM doesn't have a Continuity test, use the Resistance, or Ohms, test and check for Resistance in the Subwoofer Coil (be sure to disconnect the subwoofer wiring before performing these tests).
2) If they test out good, hook the wires back up and test the terminals at the terminal cup or at the Amp hookup if you didn’t use a terminal, don't hook it up to the amp yet. Sometimes the wiring inside the box can be a problem if it has come loose, or isn't making a great connection.
3) If you have a Sub or multiple Subs with Dual Voice Coils, or multiple Subs with Single Voice Coils, make sure your wiring is correct by checking here:
http://www.the12volt.com/caraudio/woofer_configurations.asp
4) Make sure there are no Hi-Pass filters, crossovers, or multi Channel switches enabled.
5) Replace your RCA cable/s with known working RCA cable/s from the Source/Head Unit to the Amplifier/s.
6) Check your Head Unit settings; make sure the Bass is turned up and/or the Subwoofer setting is turned On.
7) If you are still getting no or low output, try plugging in an MP3 player or CD player using a headphone to RCA adaptor and check for sound output. If there is still no or low output, your Amplifier outputs are probably burned out.
Jul 18, 2010 | Jl Audio 300/2 Car Audio Amplifier
It comes on but no base sound and wont turn up
You have to fill in the details about what you're feeding it (the source and how IT's set up). It won't just >>create<< bass.
From the manual:
If you used the high-level (speaker) inputs and there
is no sound from any of the speakers:
• Check that receiver/amplifier is on and a source is playing.
• Check that powered subwoofer is plugged into an active electrical outlet and is switched on.
• Check all wires and connections between
receiver/amplifier and speakers. Make sure all wires
are connected. Make sure none of the speaker wires are
frayed, cut or punctured.
• Review proper operation of your receiver/amplifier.
If there is low (or no) bass output:
• Make sure the connections to the left and right “Speaker
Inputs” have the correct polarity (+ and –).
• Make sure that the subwoofer is plugged into an active electrical outlet and switched on.
• Adjust the crossover point.
• Flip the Phase Control switch to the opposite position.
• If you are using a Dolby Digital/DTS receiver or processor, make sure that the subwoofer adjustments on the receiver/processor are set up correctly.
• Slowly turn the Level Control clockwise until you begin to hear the desired amount of bass.
If you used the line-level inputs and there is no sound
from the subwoofer:
• Check all wires and connections between receiver/amplifier and subwoofer. Make sure all wires are connected. Make sure none
of the wires are frayed, cut or punctured.
• Make sure that you have configured your receiver/processor so that the subwoofer/LFE output is on.
Apr 07, 2010 | JBL PB12 Subwoofer
Only powers subwoofers when at high volume
Well, make sure that the output level on your head unit is up, and also try adjusting the gain NEVER EVER PUT IT ON FULL GAIN BECAUSE THAT WILL CLIP THE AMP AND MAY BLOW AMP AND/OR SUB!!!
Oct 08, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Rockford fosgate 3002 thermal light on no sound
Is this powering speakers or subwoofer? If it's the subwoofer you need to make sure the gain is turned up and the sub is set to low pass frequency. Also make sure bass and subwoofer are enabled on the head deck. Make sure the RCA's are hooked up properly at the back of the head deck. If it's the speakers then you may have balance set to front only so your rear speakers aren't making noise.
Aug 04, 2009 | Rockford Fosgate Car Audio & Video
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
Sony XM-1652Z
What head unit do you have?
Is there a dedicated subwoofer output?
If not, have you switched the rear output to sub output?
Is the amplifier set to LPF (low pass filter), and the gain turned up?
Many things can be wrong, but the fact that there is anything coming out of the subs is a good thing.
Start at the beginning - Head unit, then check amplifier gain/crossover setting.
If you are using a hi level adapter on factory radio, is the Bass on the radio up? is the output gain on the convertor up?
Jan 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Wiring Advice
they are to adjust output levels. yes you can hook up the sub to the amp. it is not wise to hook up the front speakers with the sub though. just get a less powered amp to drive the front speakers.
Oct 28, 2007 | Infinity 475A Car Audio Amplifier
Car Audio & Video Logo
96 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
