Question about Casio QV-R40 Digital Camera
Low Battery Power
After installing new batteries, within a couple of minutes use a "low battery" message appears. I have tried replacing the batteries on numerous occassions but the same problem re-occurs.
    Scholar:
  • 125 Answers
Clean battery contact on the cover and if possible on the far side of the battery compartment (spring and metal connector). You can use fine abrasive such as 3m or scotchbrite. Oxidation buildup increases the reistance and the camera ' thinks' that the battery is depleted.
Posted on Jun 04, 2007
    Genius:
  • 2,985 Answers
Check casio web tech support for this one
Posted on Jun 03, 2007
Check engine light is on
The check engine light could relate to something else - not your battery or alternator.
If your battery isn't charging from the alternator an illuminated battery symbol would appear.
It could be many things - low oil level, low coolant level, low windscreen washer fluid level. It could even be an electronic 'fault' - which a computerised diagnostic check would identify.
If the battery warning light is illuminated the first thing you should do is to check the tension of the alternator belt. You say that a new battery and alternator have been fitted? Take it to an auto electrician - he should identify any fault within minutes.
Jan 22, 2016 | 1994 Dodge Caravan
Alert System battery voltage is low
If it's installers correctly , reseat it and verify. Try unplugging the machine for a few minutes. Did you try to reset the Time in BIOS?
May 04, 2013 | Dell OptiPlex 380 PC Desktop
Acer Aspire One PC Notebook- Mini 1GB, WXP
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge.
Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
Regards.
Jul 22, 2010 | Acer Aspire One PC Notebook
Aspire 3680 Won't charge
Have you tested the A/C to be charging correctly ? Have you confirmed that at the back of your laptop where you plug the power in that the pin is not bend and not missing or broken or pushed in ?
If your new battery and the old battery give you exactly the same issue, then most likely your A/C power adapter or cable OR the physical port on your laptop is broken and needs to be replaced.
May 14, 2010 | Acer Aspire 3680 Laptop
Nokia 8800 keeps switching off saying battery low.
sadly FIXYA can not , would recommend getting a replacement (NEW ) phone
May 13, 2017 | Nokia 8800 Cellular Phone
Motokrzr
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Sep 23, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
Casio QV-R40 Digital Camera Logo
107 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
