Samsung rts-he10 sound
Can you not connect the red and white to the tv and the red and white to the dvd to achieve this? if so where exactly do they go?
Shown, from the DVD the if you are trying to the and image from the DVD to the TV goes conected on the output, and to the TV In the input. the color dont make a diference as long as what ever color you have is on the same output - input meaning
R Output - R Input
L Output - L Input
Posted on Jan 08, 2009
Can you provide a user manual for an Inovix iDP-713D Portable DivX DVD Player Widescreen 7" demonstrating where input to a 40" flat screen Samsung UE40C85UKXXU goes?
On the back of the TV you should see the component connections. Connect the Yellow plug to the Green/Y terminal. Connect the white plug to the white audio terminal and red plug to the red audio terminal. Change your TV input to Component and you should be set.
Nov 26, 2014 | Samsung Televison & Video
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
How do I hook up my little DVD player to my tv?? The DVD player only has red, yellow, and white cords,, where to I plug it in at on the back of the tv and which setting.
New Samsung HDTVs use the GREEN RCA input for the yellow RCA video cable, plug it in there. Select the AV input on the TV. For sound, connect white RCA cable to white RCA input on TV.
Aug 21, 2011 | Samsung 50 in. Plasma TV
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
Cant connect samsung RTS-HE10 home cinema to my samsung 40" tv, which has 1 HDMI port. I also have sky hd
Connect the RTS-HE10 via HDMI to the TV and the Sky+ via scart to the TV. Then get a stereo RCA to 3.5mm jack lead and connect from your TV's stereo RCA output (red/white) to the Aux 3.5mm jack (like a headphone socket) on the RTS-HE10. Select Aux on the RTS-HE10 when you want to listen to whatever is on the TV.
Dec 06, 2008 | Televison & Video
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a samsung cinema system rts he10t and a samsung lcd tv le32a556 and i am trying to get the sound from the tv to the cinema system i have a hdmi cable and the red and white phono cable connected but...
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Nov 17, 2008 | Audio Players & Recorders
I have no sound from my samsung tv to Samsung HT-TZ315R/XEU i have connected with hdmi and the white and red plugs i have sound from the dvd player but not the tv any suggestions
Make sure the red & white connectors you are using on the TV are actually audio out, and not audio in. If you are using the connectors on the side of the tv (adjacent to the yellow connector), then these are inputs.
If your TV has no audio out connectors, then if you have a European TV, you can use one of the scart connectors with an adaptor.
Also, check the red & white connectors you are using on the home theatre system are inputs. Also check the source is set correctly.
May 16, 2008 | Samsung Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
