Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl b no recieve
It has carrier and modulation but no recieve,i test the pa system so its not the audio chip it has no ssb or am recieve,the needle in the meter is dead
  • 32 Answers
Make sure that the rf gain is turned up all the way.Check diodes D-12&D-13.
Posted on Feb 02, 2009
Cobra 142 no audio
Check to make sure the ext speaker jack is not worn out. Even the internal speaker will not work if it is worn.
Jul 26, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
148 GTL 120-Channels Base CB Radio: my 148 throws a key to my bench radio but sends no...
Hi
try replacing the transistor just before the last on the rf pa output.
Hope this helps
Ray
May 15, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
No modulation in AAM only mode. Needing a schematic.
if the transmitter produces power output with modulation on SSB but NOT ON AM then the AM Pass Regulator is defective, more times than not.
May 24, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148fgtl low power on am/ssb no swing all finals ok
try adjusting the L36,L38 to the highest reading on the external meter and then adjust VR10 TO 4 watts. If this doesn't cure the problem, you have a weak final transistor. Good Luck
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
142 GTL Good AM Carrier Weak Modulation????
you may have to scope the finals circuit on the modulation to see if all the "inline" caps are installed correctly... be sure your pc board is grounded in all areas as required by specs in your manual. Make sure there is no bleedover and you are sheilding your crystals from the modulation platform. al
Mar 24, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
340 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
